Question about Dryers
Hi i have a dryer kitchen aid that hot air is not coming out
Electric i mesure and its ok but the air that is coming out is not hot what should i do?
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Look at this video.
Posted on Nov 07, 2012
dididsaythat
  • 291 Answers
SOURCE: Electric Dryer
Dont see a model # or make  but here some tips
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a..
Hi-limit fuse that need to be checked for Continuity and replaced if bad
if you dont have a ohm meter you can hook the wires together
with a small piece of wire and by pass the themostates and hi limit fuse to see if thats the problem or not
Posted on Oct 17, 2007
  • 8 Answers
SOURCE: dryer wont start
I would check the door swith first.
Posted on Nov 29, 2008
  • 3 Answers
SOURCE: Dryer warm but not hot, long dry times
some times there are multiple heating elements in there and if one is out it does not get as hot. another simpler place to start would be to make sure your line is clear of debries all the way from dryer to out doors. this is a good idea any way since lint build up can cause the occasional house fire.
Posted on Jan 23, 2009
david04928
  • 102 Answers
SOURCE: electric dryer not blowing hot air
Sounds like the heating element is not working, make sure you are getting 220 volts to the recptical. Let us know if that did the trick. If not let us know thankyou
Posted on Mar 16, 2009
mreid542
  • 166 Answers
SOURCE: Kitchen Aid Dryer KEYE67988LD wont start
you could have several problems but the first thing to do would be to check the door switch. Most of the time you can use a small screwdriver to push the switch in and out. you should hear a click when you do this if the switch is good. you can also use an ohm meter to check the switch if you know how to use one.
another culprit is the thermal fuse located on the back of the machine. you must remove the rear panel. it is usually a small white object with 2 wires attached to it. if for any reason the machine over heats this thermal fuse will shut the dryer down. it is not resetable and must be replaced if no continuity flows through it. if it is bad usually something caused it such as a stopped up vent , crimped hose or possibly a thermostat failure. check these items and clean out the lint on the outside of your house vent as well. don't use plastic vent hose and don't try to push the dryer up too close to the wall causing the vent to partially collapse.
Posted on Jun 07, 2010
Buzzing noise from my dyer
You may be experiencing some feedback through a buzzer from the timer. Below is a link that may be of some help.
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Oct 23, 2017 | KitchenAid KEHS01P Electric Dryer
Propane gas kitchen aid dryer is not heating. Model number KGYE660WWH1, dryer is over 14 years old, any suggestions to fix it? Spoke to gas company and there is no problem there...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Dryers
My dryer, Kitchen Aid KEYS850LQ does not cool down! The buzzer goes off, I open the door to remove clothes, and they are so hot I can hardly touch them!!! The dryer is only 6 years old - it never has...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | KitchenAid KEYS850LQ Electric Dryer
Roper dryer Mod #RES7646KQ you have to dry the close twice after two times close come out hot and dry what is the problem
Check to make sure that the dryer vent is clean or open. Make sure the dryer lint screen will let air through it...... take it to the kitchen sink and run water through it if water runs through it easily it is OK if it holds water then clean it with dishsoap and try again..... The dry is not getting enough air passed through the dryer.... Also I am assuming that the Washer is wringing out all of the water from the clothes.
Jan 31, 2011 | Roper RES7646KQ Electric Dryer
I have a kitchen aid dryer SUPERBA electric dryer. It stopped drying. still runs ok but no heat. Checket the Element . looks fine . what could be the reason.?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 05, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen aid kgys750gq0 works but there is no heat
The KitchenAid KGYS750GQ0 is a gas dryer, so the solution of looking for a heating element is not helpful. There are several heat switches and a gas burner assembly (which includes a gas valve and an electric ignition), any of which could be the problem.
May 15, 2010 | Dryers
Kitchen Aid Electric Dryer Model # KEYE678BALO, won't start.
This is most often caused by a bad thermal fuse or thermostat high limit cutout. Check them for continuity (with the machine unplugged, of course) They should have continuity -- replace them if open. They should be available at www.appliancepartspros.com Also, if one or both are bad, check the dryer vent as they often are damaged by high heat due to a restricted vent pipe. The website above also has diagrams to help find the parts on the machine.
Dec 30, 2009 | Washing Machines
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Maytag model# LDE482 electric dryer won't blow hot air
Either the control panel is defective or the dryer heating element is defective.
Jun 28, 2017 | Maytag Dryers
Dryers Logo
44 people viewed this question
Top Dryers Experts
