Question about Reddy Heater-30-55,000 BTU Variable
I have a reddy 55......it comes on for about a minute then shuts off....it had a thermostat but that has been bypassed.
It's kerosene.
  • 81 Answers
There is a cad cell that see's a flame or operates the shut down circuit. Try cleaning the cad cell.
Dennis
Posted on Nov 06, 2012
  • dylanreedtay
    dylanreedtay Nov 07, 2012
    Alright I cleaned it but for some weird reason it will only run with the top cover off.....I'm assuming that photo cell is going bad and that the extra light it's receiving from not having the cover on is keeping it running. What do you think?
  • motherlode_p
    motherlode_p Dec 23, 2012
    I just went through mine, and make sure the filter is clean, and the line going from fan to the ignition point is clear. Chances are that it's still the fuel line pick up. It's under the side plate that comes off with 4 5 /16 screws. There's a rubber plunger that goes into the gas tank the fuel line goes into, a flat head screw driver will pop it out and it pulls straight up. Bottom of that tube is a filter that gets pluged. Reason it works with cover off is the fuel delivery balances out more with the air intake change.
tbugger
  • 232 Answers
SOURCE: Kerosene Reddy Heater, fan comes on, but it won't ignite
Your description does not leave much to go on, because you don’t state the model heater that you have. You see, there are 2 different technologies that come into play on portable kerosene heaters. First there is the older version spark plug type heater, and, second there is the newer computerized type with Hot Surface Ignitor (HSI) technology.
Since you state "There is no electricity getting to the plug", the KEYWORD here is PLUG. I am going to assume that you have a spark plug type heater. NOTICE: if your heater has HSI technology- disregard this post because it will not apply.
Causes for "no electricity to the plug":
  1. no electricity to the unit
  2. a defective Safety Control (reset)
  3. a defective photocell
  4. a defective Ignition Control (transformer)
  5. loss of ground to the Ignition Control
I am including a link to some troubleshooting tips for spark plug type heaters. These heaters are relatively simple, but, be careful. Stay away from the fan and take precautions from the obvious shock hazards. Troubleshoot each of the above until you find the problem.
Posted on Dec 04, 2008
  • 188 Answers
SOURCE: Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
Posted on Jun 30, 2009
SOURCE: when filled with kerosene then plugged in, the
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Posted on Jan 20, 2010
hardrocko
  • 1476 Answers
SOURCE: I have a Reddy Pro 115 BTU kerosene heater the fan
When you say that the fan starts then stops I assume you also mean that the burner starts and stops. If this is correct and the unit is more than a couple of years old you probably need to change the filter in the back and set the pump pressure. Both the filters and the gauges to set the pressure can be found at www.reddyheat.com along with a good explanation as to why you need the gauges. The pressure is set by bleed air pressure and must be exactly 3.5 psig. The gauge is the only accurate way to do it. The filters clog and change the pressure. When the difference is enough the unit will not run. Now with that said there are several other things which you should check. Check the fuel tank for water. Remove any you find. Remove the cover on the right side as you look at the unit from the front and remove the circuit board. Check for cracked connections. If you find any resolder them and reattach the board. That should take care of the unit and get you back to making heat. Let me know if you need anything else.
hardrocko
Thanks for using FixYa
Posted on Feb 14, 2010
heatman101
  • 43501 Answers
SOURCE: Reddy Heater 55 Wont Fire
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
I bought a Reddy Heater 60,000 with no manuel Its fires up runs about a minute then shuts down. I can unplug the unit for about a minute and it will come on run a minute and I have to repeat this....
Here is the owners manual:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113282-01D/113282-01D.pdf
Here is a service manual:
http://www.desaparts.com/service_manuals.html
If you have other questions you can call our service department at 1-877-475-5660
Thanks
M Cramer
www.allpartsinc.com
Jan 04, 2011 | Reddy Heater Tools 60,000 Btu Portable...
Our heater will ignite and run for a few minutes then it will shut down and not refire without powerig the unit off. also there is a heavy smell of kerosene. we are using dyed kero. we have tried bypassing...
Thanks for providing the model of your heater. Most folks don't.
Your heater has a photocell eye and a computer board (ignition control). This team monitors the flame. If the team does not like the color of the flame then they shut the heater down and that is the situation you are in. Now, you must troubleshoot & find the problem. Is it water in the fuel, incorrect air pump pressure, worn nozzle, cracked plastic cover, etc.
Read these troubleshooting tips.
Nov 04, 2010 | Reddy R115DT Oil Filled Utility Heater
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
HAVE REDDY 55, I GET NO FIRE TO THE SPARK PLUG,
heatman101
Nov 20, 2009 | Reddy Kerosene Heater with Thermostat:...
May 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
The unit should have a fuel & air filter. Check that both are clear. Inside the burner tube, there will be a photo-cell, if the lense is dirty it will shut the flame off. The photo-cell needs to see the flame. You can carefully and gently, clean the lens with a tissue, soft cloth, or Q-tip. Please let me know how its coming along.
Feb 09, 2009 | Desa International Reddy Heater R115DT...
Reddy Heater 55 wont Fire
heatman101
Feb 03, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-30-55,000 BTU Variable Logo
576 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
