Hi have a reznor xa 200 burners light for 15 sec then go out fan never comes on
2 Suggested Answers
  • 11800 Answers
SOURCE: Rinnai Convector 516TR cannot get
This happens because the gas is not lit so the heater goes in fault mode. The gas is not lit because either the valve gas doesn't open or the sparker is non-operational - both will have to be checked.
For that download and follow the service manual
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/153.pdf
Posted on May 28, 2011
Ao smith GPVH 50 100 BURNER WILL NOT STAY . EXHAUST FAN COMES ON IGNITER COME ON , BURNER LIGHTS FOR ABOUT 4 SEC. BURNER GOES OOUT
Low gas pressure, dirty combustion parts, bad gas control valve.
Following link has power vent troubleshoot:
http://waterheatertimer.org/power-vent-water-heater-troubleshoot.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 09, 2017 | Water Heaters
I have a Gasmate CH 200 column heater that turns off after 10 or 15 mins
sound like a bad thermostat - replace it with a new one!
Jul 03, 2016 | Heating & Cooling
I have a reznor heater in my garage I have to keep lighting the pilot it wont stay lit.
i have an ole reznor in my garage been workiing for ten + years no problems , mine is gas , the pilot light does go out after it switches to main burner like ten seconds later , but does light back up when thermostat shuts main off ( i had to go look to make sure) not a real big flame maybe like an inch or so , has a spoon shaped air shield around it , maybe yoours is missing ?
Mar 02, 2015 | Heating & Cooling
Blodgett gas oven 60-90 sec main b urner goes out
After burner on did you hear any spark ignitor if that your flame sensor is dirty or need to replace....good luck
Dec 11, 2013 | Blodgett DFG-100 Gas Single Oven
Reznor Heater UEAS 260 not heating
Check your igniter. If the furnce does not light it will do that every time.
Dec 09, 2013 | Reznor 205895 CC2 Vertical Vent Kit for...
Reznor UDAP-100 heater miss fires when shouting down and turning on.
check gas pressure coming in to unit or burner tubes dirty if dirty the boom means gas is pooling then lighting unsafe clean out and check gas pressure
Apr 15, 2017 | Reznor UDAP Series -100k BTU High...
Inductor blower comes on and runs then the ignitor glows flame comes up and burns for approx. 10-15 sec then goes out then fan comes on. Model number is PBKMLB12N0B0F I believe this is a goodman furnace.
I cleaned the sensor that was at the the right further most burner on my Goodman and it worked. got the answer to my problem here at fixya. My burner flame only lasted 5 secs before it shut off. Thanks to all who took the time to send me a response.
Nov 13, 2010 | Goodman Heating & Cooling
Dryer runs. No heat
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Burner lights, fan wont come on, fan runs on manual setting, has new fan switch set at 110
YOUR FAN ON SETTING IS THE SECOND SETTING ON THE SWITCH .THE LOWEST SETTING IS THE TEMP AT WHICH THE FAN CUTS OFF AT THE END OF A SUCCESSFUL HEAT CYCLE. THE THIRD SETTING IS THE TEMP AT WHICH THE FAN COMES ON MAYBE 140 ISH. THE THIRD SETTING IS THE TEMP AT WHICH THE BURNER IS SHUT DOWN IN AN OVER TEMP SITUATION SAY 200 . THEN CONSIDER THE FACT THE SETTINGS ON THE DIAL ARE VAGUE. ACTUAL TEMPS MAY BE 20 DEGREES DIFFERENT, AND PROPERLY SETTING IS USUALLLY DONE WITH AN ELECTRIC THERMOMETOR.
Oct 25, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
