Question about Canon EOS Rebel XT Digital Camera
Canon rebel xt error code 99 - Canon EOS Rebel XT Digital Camera
  • Canon Master
  • 32,281 Answers
This WEB site has a solution for this erreo code.
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Posted on Nov 07, 2012
  • 641 Answers
SOURCE: Error Message
Error 5 indicates - Something is obstructing the built-in flash....
Posted on Jul 31, 2007
jbreth
  • 69 Answers
SOURCE: canon digital rebel xt :error 1 message
I agree with dovi. I actually emailed canon and here is what they said and how to do it; Thank you for your inquiry regarding your digital SLRs. We value you asa Canon customer and appreciate the opportunity to assist you, and I'm sorry to hear that you're running into the "error 1" message. From what you mentioned, it sounds like the lens might be having problems communicating with your cameras. One thing you could try is toclean the contact points on your lens and your camera. If you have not done this yet you can do so by turning the camera off, removing the lens, then brushing those copper points on both the lens and the camera body with something like a clean eraser. Should problems continue, I would suggest that you go to a local camera shop and try a different lens. That way you can determine whether the problem is due to the lens or to your cameras. I hope this is helpful Jason
Posted on Sep 05, 2007
  • 6 Answers
SOURCE: Canon rebel XS error 99
Instead of taking out the battery, just open and close the battery compartment to reset the camera.
SVRGuy02 is right, set the slep time longer to avoid the issue so much and just open and close the battery compartment before beginning each shooting exercise
Posted on Jul 16, 2009
  • 7 Answers
SOURCE: Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Posted on Aug 22, 2009
  • 164 Answers
SOURCE: Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
Posted on Aug 25, 2009
I have canon rebel xt with promaster spectrum 7 70=210mm lens. i keep getting error code 99 on lots of shots, am i doing something wrong?
Check for bent CF pins. Remove back cover and make sure bottom right screw that holds the rear circuit board has not come out (a very common problem with this model) and is shorting out part of the board. Try another lens - if it only does it with this lens then the lens is bad, usually caused by a bad aperture unit. Promaster does not sell parts unfortunately.
Oct 06, 2013 | Canon Rebel XT / EOS 350D Digital Camera
My Canon Rebel XT shows a CF Error , I changed the card and when I tried to format it shows error 99. THe Vattery is new and fully charged and right about the middle of the CF socket there are apparently...
Welcome to Fixya
Err 99 could means several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks for choosing Fixya!
Jan 27, 2011 | Canon Rebel XT / EOS 350D Digital Camera
My canon rebel gave an error 99 and then lost all power. It won't power even with a fresh battery.
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
Apr 25, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 in Canon EOS Rebel XS 1000d
Have you been to the support section of Canon's website to find out what "error 99" means?
Aug 21, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon rebel xt eos
Error 99 means lens communication error.
Try to clean the contacts on both sides.
and re-install lens
Jun 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 message keeps popping up
Instead of taking battery out, open and close battery department to reset camera.
Sounds like you have a major fault, you should raise this with Canon and prob send for repair
Jun 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error code 99 when using EF 70-200l lens
Error code 99 means the lens is not communicating properly .
You need to remove the lens and clean it . Place it properly . If it is not placed properly you will receive this error .
Feb 22, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel Xt EOS Err 99
Error 99 is a "catch all" error that has several causes. It could be that your battery is not fully charged, especially if it is a generic, non-Canon battery. Charge for at least over night even if the charger says it's full. If that's not the cause, switches inside the camera will have to be cleaned by a repair shop.
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 msg on new canon
there is a defective flexwire inside the lens or unfortunately the opening or fstops motor is defective. flexwire is easy to repair but a replacement motor is not available or hard to find, (the magnet inside the motor is slowly disintegrating causing it to stall)
Dec 31, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT Auto focus Error 1 Problem HELP
This is a camera body contacts problem Canon Customer support will advise what to do next
Apr 15, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel XT Digital Camera Logo
51 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
