Question about Archery
Diagram on how to change draw length on a bear panther II bow
2 Suggested Answers
  • 14 Answers
SOURCE: Why does the bow length need to match my draw length?
The bow length needs to match your draw length because the bow limb is designed to be used at a particular draw length range. For instance if you use a bow with limbs too long for your draw length, you won't be able to flex the limbs enough to make them efficient.
Posted on Aug 26, 2012
Bear Compound bow. 60 draw. How much does each turn of the screw decrease the draw weight?
Have you tried this site:
http://shootingtime.com/bow-tech-basics/adjust-draw-weight/
Dec 27, 2014 | Bear Archery Encounter Compound Bow...
How do I adjust the draw on a Bear Warrior III Bow
look in the manual and you will see what number coinsides with which draw length. On each cam there is a module with numbers on them. You set these to adjust draw length.
Jan 12, 2013 | Bear Warrior 3 Compound Bow Kit
How to adjust string draw length for a bow madness
You have to reset the modules on the cams. Look in the manual for adjustment process.
Nov 15, 2012 | Archery
How can I find out my draw length?
In order to find out the exact draw length, hold a tape measure in your bow hand and then pull the tape measure as you would a bow string to the corner of your mouth.
Aug 26, 2012 | Betsey Johnson Archery
What's a Reflex bow?
A Reflex bow is a unique bow that has curved arms that turn away from the archer. The curves put the materials of the bow under greater pressure, allowing a fairly short bow to have a high draw weight and a long draw length. I personally own a Reflex bow of my own an had lots of other bows and for me it's the most powerful bow I've ever used, so you defiantly try this bow out.
Jul 30, 2012 | Archery
What's the best bow for beginners?
You can findlots quality bows in different prices, but the best bow I advise you to get,the bow I actually purchased myself, is the Parker Sidekick. This bow isdesigned for beginner archers as it comes in 18- to 28-inches of draw lengthadjustable at 0.5 inch increments. Draw weights are available from 20- to40-pounds and 40- to 60-pounds with a comfortable 80 percent let-off.
What is 'stacking'?
This isthe amount of increase in weight as the bow is drawn. It occurs in all bows,but can be intensified in three ways. First, the bow may be too short for thedraw length. A longer bow could help this problem. Second, the ratio offiberglass weight or thickness should also be increased. Third, the moreradical the limb design the more the stack will increase. This means that at agiven limb length the bow weight, a more pronounced recurve design, will stackmore at full draw. The use of multiple tapers in a limb can also causestacking.
Jul 09, 2012 | Archery
Bear polar recurve brace height
String length is 60 inches. The brace should be 7.5 to 8 inches. Listen for noise and feel for hand shock. Twist the string to add brace. Shoot for the sweet spot. When the bow becomes quiet and the vibration and hand shock is minimal, you have found the sweet spot. Measure your brace height at this point and write it down.
Mar 30, 2009 | Sport & Outdoor - Others
Archery Logo
96 people viewed this question
Top Archery Experts
Tom Chichester
Are you an Archery Expert? Answer questions, earn points and help others
