Question about Acer One Aspire 722-0828 500gb Netbook W/ Dvd Recorder Black
No power Won't power on. Where is the battery?
  • Acer Master
  • 7,627 Answers
No power at AC outlet? No battery power? Look on the bottom of the laptop. plug in the laptop it will work without a battery.
Posted on Nov 07, 2012
My mini 10v Dell won't charge the battery, and if I take out my battery to just run on power it won't turn on. The light that lights on if power is on blinks for a sec or two and shuts back of
take the battery out and hold the power button for like 15 seconds. then put battery baCK on and plug it in but do not try to power on. lets saee what goes? remember not to power on
Jan 31, 2013 | Dell Inspiron Mini 10v Netbook Computer
Changed batteries, now won't control power
It is possible you are using the wrong type of battery. A lot of electronics require you to use either Lithium-Ion or less powerful ones. I had this happen once by putting in batteries that were the right size, but were meant for more powerful devices. If you have a cheap set of the right size batteries laying around that are a different type, try those.
Dec 10, 2012 | Hitachi Clu-577tsi Remote Control
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
Nov 06, 2012 | Computers & Internet
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
COMPAQ V2030US POWER ON WON'T START
if there are no Power light,you battery might be broken or your power button is broken,i suggest you to charge your battery or take it to notebook center (if charging still failed,it might be the button)
Aug 27, 2012 | HP Compaq Presario V2000 Notebook
I purchased lenovo z 570 laptop.clarification of regarding battery i am making 0 battery for every 15 days. (A) BATTERY is fully charged (100% ) , even though iam keeping plug in socket & using...
Not really, the older NiCad batteries get a memory effect if you keep charging from a half charged state, but modern Lithium batteries do not suffer from this problem.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.These rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 10, 2011 | Computers & Internet
My 2000 licolin battery died the key won't open the door lock how do get in to the engin to put jumpers on the battery to give it enough power to work the locks ps i don't understand why the key...
The key has to open the drivers door
Raise the car up,support it,& put your battery
charger on the starter battery cable terminal
& ground the black clip
Try charging the battery for 4 hours or so
Jul 02, 2011 | 1998 Lincoln Continental
My woofer is 18' 600w rms power. so what is the
Basically you cannot break you woofer with too powerful amp, but you can break it using too weak amp. This is because if you don't have enough watts going to you woofer the cones movement isn't controlled properly. I'm usually using +20% to the woofers RMS and peak power. This will also make the amp last longer because you won't use it at it's peak performance all the time. If possible use manufacturer whose prising policy matches your woofers manufacturers, that way you won't end up with "2000w peak power" cheap amp with real output of 30w. and in the other end cheap woofer won't handle expensive amp with real 600w rms so well, you need to find a midlle way here. Hard to say without knowing the make and model of the woofer.
This is a taste question for some people, and I haven't build a system to match so powerful woofer ever in my life. But I'm pretty sure you won't go wrong with this one.
May 20, 2011 | Audio Players & Recorders
Mitsubishi Eclipse Spyder 2001 what fuse for the power windows part #
I've been messing with the stereo and took the seats out to check the amp. I don't think I disconnected the negative cable on the battery and now the windows won't do anything and the top won't go up or down. What did I screw up?
Sep 17, 2010 | 2001 Mitsubishi Eclipse Spyder
Acer One Aspire 722-0828 500gb Netbook W/ Dvd Recorder Black Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
