Question about Poulan Push Mower
Low idle after starting - Poulan Push Mower
    Sergeant:
    Champion:
  • 278 Answers
If it is powered by Briggs n Stratton donnyboy73 on youtube has a excellent video on that set up.
Posted on Nov 07, 2012
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Will not idle when cold
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
It can be issue with IAC( idle air control valve) causing the problem.
There are many other possibilities causing these idle issues. Engine idles rough.
There are few help links with solutions to troubleshoot such idle issues.
I suggest you refer the link below and follow its troubleshooting details:------
Click the link below:-----
Ford Expedition IAC valve replacing
http://technoanswers.blogspot.com/2012/12/ford-expedition-iac-valve-replacing.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1999 Ford F-150 Idles rough and quits when gas pedal is pressed less?
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
GMC Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
1996 Camry intermittent engine failure while idle?
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed?
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
High rpm in neutral? Inconsistant high RPM in neutral?
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Vehicle stumbling at idle and shows code 54?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
Rough idle, staling and Erratic shifting?
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These details will help.
Thanks.
Dec 14, 2012 | 1999 Jeep Wrangler
High idle then low idle
just do induction / throttle body cleaning - will solve high idle on start up
Nov 12, 2012 | 2002 Chevrolet Impala
MY 220K MILE 1997 NISSA TRUCK ONCE IT WARMS UP (WILL NOT DO IT COLD LIKE AFTER 30 MIN ON) WILL IDLE VERY LOW, THEN STALL OUT, CHANGED OUT FUEL FILTER, DISTRIBUTER, CAP & ROTOR, PLUGS, WIRES,...
A throttle positioning sensor or idle sensor can cause these problems, low fuel pressure can cause these problems also low fuel pressure can be caused by a faulty fuel pressure regulator.
Mar 19, 2011 | 1997 Nissan Pickup
When car sits a for a while it's hard to start and very low idle
my first ting to check would be battery, as since it is occurring when it sits for a while, then this would be the most likely source as the alternator charges the battery amd since the battery is low on charge, then this also causes the low idle
Jun 14, 2010 | 1994 Honda Civic
Engine will start at very low idle, sometimes killing, then may fast idle, then low idle, back and forth. What may cause this?
check and make sure air filter is ok, and there are no restrictions in hose to throttle body, check iac (idle air control.
Oct 01, 2009 | 1990 Chevrolet Corsica
Low idle problem
simply just tighten up the accelerator cable so that on idle it hits 750rpm or slightly more 800rpm if your engine condition isn't that good.
May 26, 2009 | 1994 Mazda 323
1992 Mitsubishi Eclipse battery seems to drain & idle high/low
check for vacuum leaks in failing hoses and loose fittings
May 26, 2017 | 1992 Mitsubishi Eclipse
Poulan Push Mower Logo
63 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
