Question about Microwave Ovens
Smh1611b door won't stay closed
Door catch does not hold.
    Top Expert:
  • Microwave Ovens Master
  • 14,553 Answers
Either a bad latch unit or one out of position---has to be opened up to see which.
Posted on Nov 07, 2012
Door won't engage and stay closed
Possible that the lock was broken and so the door opened. You can remove the front panel and check for broken plastic or nylon pieces which can be glued using instant adhesive.
Reset the lock and switch and the door must lock in correctly
Jan 21, 2013 | Microwave Ovens
Samsung microwave #SMH1611B door won't close
If it has the "double hook" type latch on the door,see if the hooks slide up and down.They should be spring loaded,if not,the spring attachment point inside the door may have broken off(my Sharp Carousel did this).I pryed the plastic door trim loose,and reattached the spring by using one of the slots inside to hold a metal wire clip(modified with needle-nose pliers) to hook the spring onto.Your door's design may be a little different,but a similar solution will probably be apparent after you get in there.
Dec 18, 2012 | Microwave Ovens
Sharp r520kst door won't stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Aug 20, 2012 | Sharp Microwave Ovens
Door on Sharp R-K520S won't stay closed.
check the hooks and door release button and repair or replace, when this is broken, the switch is not close the microwave will not START.
SEE the diagram
God bless you
Jul 14, 2012 | Microwave Ovens
Microwave just won't stop
One of the door switches is defective, sometimes caused by food particals this is a safety issue and should be corrected.
Mar 08, 2012 | GE JE1540 Microwave Oven
Door has been an issue when closing light stays on and you really have to slam the door for the light to go off
Door catches.
Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. The door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Jan 24, 2011 | Whirlpool GH4155XPS Microwave Oven
Door catch broken - door will not close. no sign of a broken piece. There was a bang and the catch just doesn't hold at all. door swings open
Door catches.
One of the latches has broken off and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Door switches
If one of the door interlock switches is not switching properly, that can cause the turntable/light to come on even though the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Jan 12, 2011 | Panasonic NNA554 Convection/Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
