Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
Steering skips and won't turn wheels on john deere srx 75 rear engine mower
  • arthur burge Nov 08, 2012
    pulled steering apart and found bushing busted. thanks for help though.
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
  • 150 Answers
SOURCE: John deere 68 riding mower steering column won't
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Posted on Sep 27, 2010
Testimonial: "sounds good will try to fix it thx"
  • 102366 Answers
SOURCE: John Deere RX 75 mower
http://www.deere.com/servlet/com.deere.u90785.productcatalog.view.servlets.PublicationsSearchServlet?
Posted on May 19, 2011
JOHN DEERE SRX 75 BATTERY IS DEAD AFTER MOWING. MUST CHARGE BATTERY TO START AGAIN.
does your mower have a alt if it does then its not charging the battery check wiring may be loose or broken.
does battery "hold" the charge???
May 14, 2017 | John Deere Garden
How to I remove the steering wheel from SX75 John Deere riding lawn mower
I have not been able to pin down your exact model but this link is to another model that may give you the info you need. john deere 214 steering wheel removal
Oct 17, 2016 | John Deere Garden
John deere srx 75 starting with key doesn't work why
if u wiggle the gear shift lever , holding key to start does it work ? if so then u need a new or adjustment neutral safety switch (also key does have running deere on it ?) as non factory keys don't work to well either
also this machine is listed on jd tech site as one that has been noted for an "starting improvement kit " part # - AM107421 jd has made it plain that they know it doenst start so well ,so they have released this kit to install that improves its starting
May 25, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere l130
There's a gear on the end of the steering column that's broken or the roll pin used to hold it on is sheared.
Jul 18, 2013 | Garden
Steering Wheel will turn when mowing. Trying to get steering wheel off as given in the John Deer Manual, but steering wheel frozen and won't budge. What else can be done to remove the steering wheel...
If you have the main nut removed, you can give the steering shaft a few shots of penetrating oil like Liquid Wrench or PB Blaster (available at auto parts stores). After lubing, let it soak at least a few hours. 24 is good. You may have to get one of those cheap "gear pullers" from like the Harbor Freight store to finally pull it off though.
Aug 13, 2011 | John Deere Garden
What Engine Model Number is in a John Deere LT166
http://www.deere.com/en_US/govsales/purchaseguide/PDFs/124_125.pdf
Will give you all the info you could need about the LT 166.
The LT166 uses a 303777 Briggs & Stratton Engine
The LT180 uses a FH500V-AS32 Kawasaki Engine, 4 Cycle
The LT190 uses a FH580V Kawasaki Engine.
The LX289 uses a FD501V-DS04 Kawasaki V-Twin Engine.
The X354 uses a FH721V Kawasaki with 4 wheel steer.
Hope this helps.
Apr 13, 2010 | Garden
John deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Jul 14, 2009 | John Deere Garden
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
70 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
