Question about Whirlpool GW395 Gas Kitchen Range
Gw395lepq00 error code E1 and F5
Oven won't lock and clean. keep getting error code E1 and F5. understand this unit has had an on-going problem.
SOURCE: On a Whirlpool Super Capacity
What is the fix for this error message, my oven door is not locked, but the error message keeps appearing.
Posted on Feb 03, 2009
  • 333 Answers
SOURCE: I am trying to self clean my Whirlpool stove/oven.
use easy offoven cleaner. when using the self clean feature the oven gets so hot that it's likely to burn out some of the electrical components
Posted on May 20, 2010
Testimonial: "Thanks I had the same thought. Hubby tried unplugging and nothing changed. Oh well, Easy Off..is for me. =) "
heatman101
  • 43501 Answers
SOURCE: Whirlpool Self Cleaning oven error code
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Jul 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: F5 E1 error code...i cant
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#@#
Posted on Oct 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: self cleaning F5 error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$TRE
E-1 & F-5 come on after about a minute when attempting to use self cleaning. the micro switches work & the solenoid has been replaced. could it be the ERC ?
Oct 21, 2011 | Whirlpool GMC305PD Electric Single Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My whirlpool oven locke with F5 E1 what to do
Thanks
Oct 05, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Trying to clean my whirlpool oven. when it start button, an E1 - F5 comes up. What is this telling me.
What the F5-E1 error code means is that the door lock asm. is not operating so when its suppused to close and lock the door to self clean it cant do it since something is wrong with the latch/lock assambly
Some of the things that would need to be checked to see why the latch isn't working are;
the latch position switch,the latch itself to be good and opening/closing, & the part called the soloniod that is what operates the latch so it could open or close
GENE
Sep 18, 2011 | Whirlpool Ovens
My 2001 Kenmore oven error says ``E1 -F5-`` What does that mean
The E1- F5 error is a door lock error. The control has likely failed. Sometimes when you disconnect power to a range and reconnect it the electronic range control gets messed up.
You should disconnect power for 15 seconds and reconnect and see if that helps.
If it doesn't fix the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.Then turn off power again for 15 seconds and back on. Sometimes these work, but if the control has failed it won't make any difference.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Kenmore Ovens
Oven door is locked after trying to clean and getting error code E1 F5
E1 F5 means your unit is having a problem with the door latch and lock assemble turn the power off for 10 min. and after turning the power back on wait another 10 min. before opening
Apr 05, 2010 | Whirlpool GMC305PD Electric Single Oven
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Apr 07, 2009 | Ovens
I used the self cleaning oven and now it wont unlock and it keeps beeping f5, e1 what does this mean and how can i unlock the oven?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&URTGF
Mar 27, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool GW395 Gas Kitchen Range Logo
64 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
