Question about Carrier 36KCARMS Air Conditioner
Hi i have kelvinator ksr25f split system the remote control is active but wont turn the unit on. the unit will run when i use the "forced operation" switch is there anything i can do to use the remote again? Adrian
  • 70 Answers
If fresh batteries dont help check if sensors are clear try removing power then restart unit
Posted on Jan 05, 2009
I have a kelvinator ksr25f split system.The green light on the front panel flashes when the unit is turned on.The unit cools ok and when the temp is cool enough the outside unit stops as normal but doesnt...
Check and make sure the outside fan is running. The KSR series Kelvinators were rebadged LG units. It is possible the 6uf fan capacitor on the outside unit has failed.
Mar 04, 2014 | Heating & Cooling
I have a Kelvinator Reverse Cycle air conditioner - Model # KSR25F-01. When I use the heating operation the "Defrost Mode" has come on and is stopping the air conditioner from working. The unit...
The Kelvinator technician came out and found that our gas was very low indicating that there was a leak somewhere - the gas should never deplete apparently (being a closed system). He checked inside and outside and couldn't find a leak so assumed it must have been an issue with the piping in the walls. He recommended not spending the money to get it repaired - he recommended it be replaced (not a cheap option but it was 11 years old and repairing wasn't likely to be cheap or a long term solution). So not sure if that is your problem but hope it helps!
Jun 13, 2011 | Heating & Cooling
The unit is a Kelvinator Air Con unit - Model #KSR25F-01. The unit will turn on manually but not from the remote. The remote has new batteries, but will not start the unit. The only button that the unit...
take the remote and put it in front of your cell phone.turn on the camera of your phone and push the buttons of the remote.if you see a light in your phone the remote is ok and then the eye of the pc board(is a small plate)has problem.
Dec 06, 2010 | Heating & Cooling
Help! I have a Kelvinator 2 KSR25F split system a/c that is not working. Every time I turned it on it trips the safety switch. I had a guy come out and look at it and he told me that the compressor is gone...
The compressor is the last resort. there could be another problem causing the system to trip circuit. sounds like a wire grounding inside the condensing unit control panel located at the contacts. check there first and inspect the other wires inside the panel of the outside unit before you decide to replace either a compressor or outside unit.
Nov 27, 2010 | Electrolux Heating & Cooling
Hi, I have a KSR27g split system air conditioner. The unit turns on with the button on the front under the panel. The unit will not turn on with the remote (remote is brand new) have tried different...
Judging by the model number, it is a Kelvinator unit. You can check if the remote works by using your phone or digital camera. When the camera is on, press a button on the remote whilst aiming the remote transmitter at the lens of your camera. If you can see a burst of light, the control works and the receiver on the indoor unit is the problem. If not, the remote is the problem.
Hope this helps
Mat
Jul 14, 2009 | Electrolux Heating & Cooling
Water is not entering my swamp cooler. Could the problem be that the main water line is clogged up, and if so how do i check it?
hi i have a split system air conditioner ksr25f kelvinator but i cant find a manual and i dont know what the buttons on the remote send for can someone help thanks
May 11, 2009 | Heating & Cooling
Remot control not working for this unit
change batterys if not working contact tech support from kelvinator
Feb 26, 2009 | GE Zoneline AZ38H12DAD Split System Air...
KELVINATOR AIR CON
More than likely it is the remote sensor in the indoor unit. Then again I presume that it is the correct remote control. Sometimes a remote for one aircon may not communicate with another aircon even if they are the same brand.
Jan 24, 2009 | Heating & Cooling
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
Carrier 36KCARMS Air Conditioner Logo
743 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
