No audio output device installed
Hi i have an advent roma 2000 laptop. i connected it to my hd tv months back via an hdmi cable. since then i have had the little red cross on the sound icon saying as above " no audio output device installed" when i look in device manager, there is no audio option to chose
  • 7,627 Answers
Under sounds no audio is installed, scan for hardware changes, still no luck try this: Try a "Cold-Start",Remove all media, DVD, CD, USB..etc., Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and Start normally. Check device manager for audio, scan for hardware changes. reconnect to tv.
Posted on Nov 07, 2012
How do I hook up my Apple TV to onyko 8050 receiver?
Hi Barry
AppleTV has 2 Outputs on the back. One is Optical for Audio Only and requires a Toslink fibre optic cable to get the good quality audio into the 8050 receiver via the Game 1 Port.
The second connector is HDMI which is a compact low profile cable which transfers both HD1080 Video and Left & Right Audio to another device.
The built in WiFi should be picking up your Router WiFi in the house and transferring iTunes music to these Ports. Just play a song on iTunes on your computer & click the icon to select AirPlay on your ATV.
There are a heap of HD TV's and Amp's etc using HDMI these days.
It's the simplest way to get connected & its the best quality.
Unfortunately the Onyko 8050 uses a proprietary port which is not directly compatible.
I noticed all the Video Ports on the back of the Onyko are the old fashioned Yellow RCA connectors. (Called Composite Video.)
There are converter boxes & cables of various sorts that you could use on eBay, Amazon etc.
See: www.amazon.com/HDMI-RCA-VGA-Cable-1-8m/dp/B002ZUI68G
Further Help:
https://discussions.apple.com/message/16046694
http://www.miniinthebox.com/hdmi-to-5rca-cable_p399811.html?currency=AUD&litb_from=paid_adwords_shopping
NOTES:
Many modern Amplifiers also become the main SwitchBox to transfer Video & Audio from one device to another. eg. My Pioneer VSX-922 has 5 HDMI input ports and 1 HDMI output port along with an assortment of RGB & Toslink Inputs & Outputs.
This way (via remote control) I can choose the Apple TV to Connect to the Plasma HD TV or The DVD Player to play Video or Audio to the Speakers. HDMI Makes the cabling so much easier.
For Future reference, when checking out new HiFi gear, always check the ports on the back of the unit.
Your Ports/Cables go by age.
1: Yellow-Composite Video RCA Plug (oldest)
2: Red & White RCA Plug (Audio Left & Right)
3: S-Video-Mini Din Connector (Video Only)
4: RGB- Component Video (Red,Green,Blue-Video Only)
5: DVI- Digital Video Interface (HiDef Video Only)
6: Toslink- Fiber Optic (Audio Only)
7. HDMI-High Definition Media Interface (HD Video & Audio)
I Hope this Explanation Helps Many Others with Similar Problems.
We don't get paid for Assisting People ... So!
If you find this helpful....
PLEASE Click the Button to Acknowledge!
Jun 29, 2014 | Onkyo TX8050 Network Audio ONLY Receiver
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
On my advent roma 2000 laptop, randomly the screen went black when i turn it on but it comes on at the start for 2 seconds then goes off..? what do i do
its overheating,check whether your fan is working, otherwise open it and clean it out, do not use a blower, the spinning fan can overcharge your motherboard and blow it
Oct 23, 2012 | Advent Computers & Internet
No audio input from TV on DVD Home Theatre
U have audio signal incompatibility. If the audio output is digital it may not work with an analog input, etc.
May 08, 2017 | Audio Players & Recorders
I wanna connect my laptop(lenovo G450) to samsung series 4 lcd through hdmi cable
A HDMI cable can output both audio and video, whilst some computer with Windows XP cannot automatically switch to HD Audio output as Windows 7 can. Thus manual setup can solve the problem.
After connecting the HDMI cable, Go to "Start" > "Control Panel" > "Sounds and Audio Devices", double-click "Sounds and Audio Devices. Select "Audio" tab on "Sounds and Audio Devices Properties" window.
On "Sound playback", change "Default device" from "Conexant HD Audio output" to "NVDIA High Definition Audio".
Your television should have several HDMI ports, select the appropriate HDMI port number and check if TV is not muted.
Hope this helps.
Jul 13, 2012 | Lenovo Computers & Internet
I am having HDMI output issues to my HD TV. The issues are intermmitent. I have my HD cable box, BluRay Player both hooked into the reciever via HDMI. The Hdmi output of the reciever feeds my TV. I have...
Have you proven that a straight shot HDMI to the TV from either source solves the problem?
For all we know the TV or it's HDMI cable could be faulty.
Apr 09, 2010 | Onkyo TX-SR606 Receiver
I need a diagram of how to hook up my jvc 5.1 surround sound to my tv, dvd and cable box
I my self don't have that exact unit, but most are similar, and i have looked up the specifications which are:
Inputs:
1 x S-video input
1 x Composite Video Inputs
1 x Digital Audio (TOSLINK) Input
1 x Stereo Audio Input
Outputs:
document.write(neg_specification_newline('1 x S-Video Output
1 x HDMI Output')1 x S-Video Output
1 x HDMI Output
INPUTS (coming from devices to the system):
1) The unit already comes with a DVD player, correct? If so you don't need to connect it. If you do, connect your DVD play via an s-video input, since a normal DVD player doesn't need a higher quality/resolution input.
2) Connect your cable box to the home theater system via a composite cable (the one with Red green blue), if it has composite outputs ofcourse. If not, do it visa versa with the DVD, if your dvd has composite. So make the dvd via composite and cable box via s-video.
3) Audio from the dvd, this would be via Digital Audio (TOSLINK) Input or stereo audio input. the digial audio will give you true 5.1 surround sound, and the stereo will only give you left and right channels, like you would hear from anything else (like a normal cd, radio, etc).
4) audio from cable box, would be again depending what you want. If you cable provider gives you alot of programming that has 5.1 surround sound (mostly HD channels), you would be better off with the digital audio. But if you watch more via your DVD, then connect the cable box via the stereo input. Again, this is to your preference, and which one you want true 5.1 surround sound from. The system should be able to 'emulate' 5.1 surround sound via the stereo cable too, but if your watching a movie, it can't really tell if a sound is supposed to come from the left rear or the left front.
Output:
5)connect to tv via HDMI if available, or S-video.
HDMI is much higher resolution (HD quality) S-video is normal cable programing or 'dvd quality'.
And the Tv would be left on mute or volume=0 since no audio is connected to the tv! All the audio should now come from your system.
Sorry if this was too vauge, but I don't have the same system and dont know exactly what/where all the connections are. If you have any other questions let me know.
Feb 26, 2009 | JVC THD-50 System
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
