Question about Frigidaire Ovens
I have a frigidaire mef352bgwd electric range does it have a fuse box?
Having a electrical problem does it have a fuse box?
  • 833 Answers
SOURCE: Frigidaire ES400 oven controls
Contacts are fused.  Get a new one, cut the power and replace it.
Posted on Nov 12, 2008
  • 17 Answers
SOURCE: Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Posted on Jun 09, 2009
protek480
  • 1714 Answers
SOURCE: F13 flashes on my Frigidaire electric range
F-13
Control's internal memory may have
become corrupted.
1- Press Cancel key.
2- If fault returns disconnect power, wait 30 seconds and
reapply power.
3- If the problem persists upon power-up replace the display
board.
Posted on Sep 26, 2009
SOURCE: I have a frigidaire mef352bgwd electric oven-
There is a pin that tells the oven the door is open, you need to push it in an hold it. It is pretty stiff, you can't use your bear hand. It will be in the upper left of where the door closes.
Posted on Mar 05, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Electric Range f10 code
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
I have a frigidaire ffef3017zw 30" freestanding electric range and the stove top and the oven wont heat. The lights come on but nothing works.
Good Afternoon Larz, thank you for your post!
From the information you have provided the cooktop and oven on your Frigidaire range, FFEF3017ZW, are not working. This could be an internal issue with your control panel, a wiring harness, or the terminal black. Since it could be an issue with the electrical component, I would suggest having a professional technician out for a proper diagnosis. This will help you to avoid any unnecessary part purchases or improper disassembly of the range. I hope this information is helpful. -Matt
Apr 28, 2016 | Frigidaire Ovens
Why won't my double oven lights or power go on?
I think it would be a good idea to find the electric box and then:
1) find the circuit breaker or fuse that controls the oven.
That information is supposed to be written on the inside of the door of the electrical box.
2) Turn off the circuit breaker, or remove the fuse that is supposed to be the one.
3) Pull the oven out from it's place and try to get behind it to test (with an ohm meter or a multi-meter) and see if the unit is getting electricity at all.
Obviously, you will need to turn the breaker back on or screw in the fuse.
BE CAREFUL, THIS IS DANGEROUS STUFF YOU ARE DOING.
Sounds like you may need to reset the circuit breaker ( that means to turn it off and on a few times) or to replace the fuse.
God bless you in your efforts.
Sep 04, 2015 | Maytag MEW6627B Electric Double Oven
The preheat indicator stays on my electric oven? What could be the problem?
I appreciate your inquiry, Sidney!
I see that you are having a difficulty with the preheat indicator on your Frigidaire range constantly staying on. This could be a possible issue with that switch or indicator light. I would recommend seeking help from a certified technician for exchanging or replacing any electrical components. This will prevent any personal injury or future issues with your range. I hope this is helpful information. -Matt
Aug 13, 2015 | Frigidaire 30" Self-Cleaning Freestanding...
Hi is there avfuse box or fuses on the stove?
If its an electric stove the fuse panel should be in the upper back of the stove. Ours was in the top behind the clock. There should be a fuse for each burner and one for the oven.
Jul 19, 2015 | Ovens
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
While preheating my electric frigidaire smooth top oven, we heard a loud pop and saw a flash. The breaker had tripped. After resetting it, the clock and digital features still work, and so does the st
I appreciate your inquiry, Stephanie Givan!
From what you are describing it sounds like a possible short with your breaker box or issue with your terminal block within your Frigidaire range. I would recommend reaching out to a professional technician for a proper diagnosis to be completed. The technician will have the correct tools to check for any electrical issues within the range to make sure the correct component is being replaced. This will help avoid any unnecessary part purchases. -Matt
Nov 12, 2014 | Frigidaire Ovens
Electrical
Have you checked oven fuse in house hold fuse box.
might be time to call appliance repairman
warmest regards
Richard The Repairman
Mar 27, 2014 | Belling Ovens
Electric stove
Check the thermal coupler a copper thermometer for your stove after checking all the fuses in stove and circuit breaker box of house to see if any have tripped. Circuit Breakers should have the switches all in a line. Any not in the lie will be tripped. Fuses in your stove are usually in the top part of the stove where the instruments are and fuses screw out and visually are easy to detect if they are blown or not. Remember all ways Unplug what you are working on to prevent shock
Jul 03, 2013 | Ovens
Fuse
According to the Manual, section about Electrical Connection Pg14 is that there is no fuse as it is connected to the buildings main fuse box via a double pole switch between oven and the mains electricity.
UserGuide\Manual
Oven Diagrams
May 02, 2013 | Zanussi ZBF260 Electric Single Oven
Oven light sockit for cmef377cisi electric range
Hello Muhammad Alvi - What exactly is the problem you are experiencing? With this information I can assist you further with the issue the range is having or any part information you are requesting.
Dec 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
