Question about Dell 540 Photo Thermal Printer
Dell 540 photo printer
My printer starting printing pictures with green and red vertical lines in them. I have tried new ink and paper and tried printing from the computer and memory stick. it still does it. i can print a test page and it is fine, but photos are liney. Dell had no solution, but to say that my printer heads were bad and it was no good anymore. it has only had about 200 uses since it was purchased. any help would be appreciated!!
  • terra faubel May 22, 2007
    Thanks for the info. It is out of warrenty. Is there anything I can do to fix it?
    Genius:
  • 2,985 Answers
Looks like to heaters are going How long have you had it Still under warranty? If so send it back or ask for a replacement.
Posted on May 22, 2007
  • john ash
    john ash May 22, 2007
    Nothing for you to fix. if the heaters are burned out then that's it; its a dead printer
    But before you junk it
    Do get on to Dell tech help- or better still as Dell do not actually make peripherals such as this but simply buy a regular model and put their label on it- carefully examine it for any tell tale indicator who did maker it- it may be a patch of lettering molded into the plastic for example - or by comparing the refill pack with a similar one from a regular maker - then when you have found out -get onto them.
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
This evening I bought a new HP Photosmart C4780 printer. I am trying to print photos now and the photos are being printed with small vertical lines across the whole photo. How do I get rid of them?
> I bought a new printer
Take it back, and get one that does work correctly.
> VERTICAL lines ACROSS the whole photo
Hold the paper in "portrait" mode, not "landscape" mode.
Are the lines HORIZONTALLY-ACROSS the paper,
or VERTICALLY-DOWN the paper?
If those lines are WHITE and HORIZONTAL,
then some of the many ink-jets inside the print-head are *CLOGGED*.
Run a "print-head-cleaning-cycle" to try to unclog it.
Or, exercise the WARRANTY, and get it replaced.
Sep 24, 2010 | HP Office Equipment & Supplies
Dell 720 color cartridge doesn't seem to be printing with enough 'green'...all pics tinted red. New cartridge. Is is possible to balance the color any better?
Run a "print-head-cleaning" cycle -- some of the ink-jets may be clogged, thus reducing the amount of ink reaching the paper.
Try "photo-quality" paper.
Jan 28, 2010 | Dell Inkjet 720 Printer
Only prints top half of picture...
Throw it away the Thermal heater has failed and it will cost more than the printer to fix. Dell will not support this item so lie the rest of us you are stuck with a Lemon. Yes Dell sucks, yes they **** again and yes they will keep sucking!
Aug 07, 2009 | Dell 540 Photo Thermal Printer
Vertical line appears on the paper, when copying/printing from the top feeder of my Dell 962 All-in-one printer
I think this is due to some nozzle on the cartridge that doesn't jet because it is clogged ( hardened ink )..Try to wipe the cartridge in a damp cloth and print again..I hope this could help...
May 18, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
email me at kissnickerson@gmail.com and I will tell you how I got mine to prin the whole picture again.
Dec 03, 2008 | Dell 540 Photo Thermal Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Dell A940 smeared printing
Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
Maybe it will work for you! Good luck!
Dec 11, 2007 | Dell A940 All-In-One InkJet Printer
Dell 540 Photo Thermal Printer Logo
139 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
