Question about Hitachi 42HDS69 42 in. Plasma Television
Blue and red line on tv screen afe it fell on the carpet
    Problem Solver:
  • 9 Answers
Sounds like a damaged screen panel they are very fragile
Posted on Nov 07, 2012
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Hi,,i only see two colors on my tv screen,blue and white,,waht should i do..please help me
there are three primary colors from your TV's chroma circuit, red green and blue..
you'll notice it when you open your back cover of your television set, the wire colored red, green and blue.. you better leave it to the expert technician to prevent severe damage
Sep 15, 2011 | Sharp 27F543 TV
Sorta looks like 3d red&green mostly also has red lines arching across bottom 1/2 of screen
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 14, 2011 | Zenith R57W46 57" Rear Projection...
Tv showing two pictures. it is blurry and mostly blue, red in colour
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Toshiba 42H81 42" Rear Projection...
Blue lines on screen...
Try Encompass Parts 1-800-638-3328
Dec 14, 2009 | Televison & Video
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
The tv is showing red lines on the screen.
These are retrace lines. The screen on the red tube is turned up too high. Inside the set there are 6 knobs. 3 for focus & 3 for screen. Turn down the red screen until lines are gone. These knobs are usually found by pulling of the front panel.
Apr 06, 2009 | Televison & Video
Tv Model no HTF27R11 SCREEN LUCKED
your problem is in blue video output circuit.
as you are seeing lines with blue  color
those lines are called retrace lines.
please check
  • supply to blue video output ckt.&blue video output transistor.
  • loose crt base or crt base connector.
  • componenrs related to blue video output section
  • blue signal coming to red video output ckt from signal processor.
  • at last but rare cases crt weak.
  • hopr this will help
good luck
Oct 16, 2007 | Haier HTF27R11 27" TV
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Hitachi 42HDS69 42 in. Plasma Television Logo
15 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
