Question about GE Iti Caddx Nx4 Control Panel 48 Zone Networx
I need reprogram caddx networx nx4, I don't have the master code.
How do I reset the Master code in DAS NX-4--8 alarm system when the existing Master Code is not known ?
Be sure you understand the difference between a master code and the technician code. A master code lets you program other codes (and do some other harmless stuff). The technician code lets you do anything in the panel. If no master code is known you will need to default the panel. Do that by turning off power and disconnecting the battery. Reconnect the battery or plug pack and within 10 seconds enter 971300 on the code pad. That will wipe the eeprom back to factory defaults, and reinstate user 1 as a master code with a value of 1234. Don't even think of doing any of this without an INSTALLER manual. (Not the same thing as the USER manual). Better still, get an alarm tech familiar with DAS or CADDX products to program it for you. Worth every penny. After that you can add/delete users with your own master code using the much simpler User manual. Any code can be set to be a master code (that is you can have more than one master code)
Jun 25, 2014 | Home Security
Installation manual
need to install nerf bars on jeep wrangler 92 have part #b07s0906
Jan 03, 2014 | GE Caddx Networx Fixed English LCD Keypad ...
I am not getting DC power to the Battery. When I check the ohms across the fuse I get 0. So I am guessing the fuse has blown, though I cannot see it visually. I do not see a part number of the fuse. ...
Just bring the fuse to the electronic store and let them find them the exact fuse that you needed for replacement. or bring your device to a reliable technician so you'll have a guarantee that if ever the fuse replacement is wrong he will be responsible for the in correct replacement of the fuse in your device so he will do something about it...Hope it will help you
Jul 13, 2011 | GE Iti Caddx Nx4 Control Panel 48 Zone...
I forgot my password for my Caddx NX-8 Alarm. It was installed in 1999
My caddx nx-8 system, have started going into a instant alarm mode for no reason, what can I check for this?
Mar 30, 2011 | GE / Caddx Networx NX 8 Control Panel...
I dont seem to get power to control panel. battery also not charging
These alarm panels receive 16.5 VAC from a small wall adapter that is wired into the keybus and labeled 'AC'. Have a certified alarm company or installer check your system for faults and get things in order.
Mar 02, 2011 | GE Iti Caddx Nx4 Control Panel 48 Zone...
Can I adjust the volume on my GE Networx NX-148E keypad?
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
Feb 10, 2011 | GE / Caddx Networx Programmable LCD Keypad...
Hi, i'm using the Caddx NX4V2, the fire light flashes rapidly and no keys are working to stop it, i did read a manual that says the rapid flashing fire led means that there are problems ... how do i pin...
If you know the 'go' code ( default 9713 ), you can press *+90 to see the event log, which you scroll through with the arrow keys on the keypad (alpha keypads only). If that is not available, you will need to have a certified alarm installer come and check your system for faults.
Dec 13, 2010 | GE Iti Caddx Nx4 Control Panel 48 Zone...
Hi Liam here I just installed a networx nx4 and when powered up key pad has 1,2,3,4 flashing rapidly with service light on I was able to get rid of service light but zones still flashing And there is only...
This could be a supervision problem. If zone expanders, gsms, keypads, etc. are added to this alarm panel, you must enroll the device with the control panel. This is done by entering into programming mode ( * + 8 + {go code} ) and then simply exiting programming mode by hitting the exit button. The GE NetworX control panel and it's affiliated compatible devices will auto-enroll after about 15 seconds. The default 'go' code is 9713, but this is usually changed by the alarm company installer.
Apr 21, 2010 | General Electric GE NX-591E-GSM NetworX...
GE Iti Caddx Nx4 Control Panel 48 Zone Networx Logo
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
