Question about Kenmore 19001
Sestem error I have the kenmore 19001 and i was using a memery card in the mechine it was working fine. after i took the card out and turned the mechine back on it made a noise like it was hung up and and showed a error with a box and the number 1. I unpluged it and repluged it back in, but it is un changed. It did this the other night, but came back on after i unpluged it and repluged it in a few time , and worked fine. I tryed everything i could think of , but not haveing any luck. What do u think the problem is? Thank u. mistyla
My kenmore 19001 has an error #1 what does this mean
Usually the manual will list common error codes under the troubleshooting section. You can probably also contact Kenmore Support.
Apr 28, 2016 | Kenmore Sewing Machines
Looking for scanner and r/w for kenmore 19000
I have one I am willing to sell. You should be able to respond to my account if you are still interested. I purchased a newer machine last year and no longer use mine.
Feb 10, 2014 | Kenmore 19001
Kenmore r/w 19000 communication error
It will only work with windows 95 systems
Nov 16, 2012 | Kenmore 19001
My Kenmore 19001 touch screen works when I am sewing regular stuff, but when I put in the embroidery card - I can see the designs on the touch screen but nothing happens when I try to go to a design. I...
to recalibrate the machine press the stop/start; the reverse; and the knot button at the same time and while holding it down turn the machine on.
Sep 28, 2012 | Kenmore 19001
How to raise feed dogs
I would check back with the repair shop, they are the one's that turned it off for you, I'm sure!
Sep 19, 2008 | Kenmore 19001
Fuse keeps blowing
Have him check power suply link, from fuse to wall plug, theres a short some where between the plug and the fuse.
Jan 13, 2008 | Kenmore 19001
Card reader connection
Buy a USB to Serial Adapter. I bought one made by IOGEAR and have had not problems,
http://www.iogear.com/main.php?loc=product&Item=GUC232A&PHPSESSID=119a3d80d289daeb12185ff1ee32e7ff
Dec 17, 2007 | Kenmore 19001
Sewing Machines Logo
19 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
