Question about Neurosmith Together Tunes Soft Musical Cube by
Need a battery for together tunes cube - Neurosmith Together Tunes Soft Musical Cube by
Tip
You can do the Bedlam Cube as shown on the Dragons Den
Thought I would photograph this to help me do this cube still have not got it back together since my 3 year old took it apart.
Here are the four sides of the cube completed to help anyone who needs to complete it before 2011..
http://www.facebook.com/album.php?aid=2044337&id=1301947832&l=bf5bd07bc6
Happy Cubing its listed in the Sports Locks section as you might need to lock yourself in a room for days so its a kind of sport.
on Jan 07, 2010 | Locks & Locksmithing
What causes my ice maker to drip water?
HI,
This could be either the ice maker is old and the finish inside has depleted, the water valve is going bad or you had a jammed ice cube and now it overfilled. Many different reason this could happen. Does the ice cubes stick together with a bridge? Is the drip coming from the ice maker head unit? How is the ice in the pan its stored in, stuck together? In the pan, has the ice glaciered together? Need more information please. Thanks
Aug 09, 2014 | Kenmore Top Freezer Refrigerator
Is there a reset button on the cube?
Unfortunately, the cube does not have a reset button. The way to reboot it is to remove the batteries and put them back in.
Jun 29, 2013 | Vtech Alphabet Activity Cube
Ice sticks together
the ice cubes stick together because the water level in the tray is to high and the cubes can not be separated so turn the valve on the wall behind the unit closed some to lessen the amount of water in the tray
Apr 05, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Panasonic RF-B65 short wave radio won't tune to frequency when turned on, just flashes 'E' and turns off automatically. Any suggestions ?
RF-B65 has a known issue with the power connector on side. It gets resistive from not being used. If you apply 6 vdc and it works, its most likely the batteries or the power connector. If both produce a "E" its PLL doesnt lock. Power plug most likely issue. Another issue is the tuning knob. It skips or jumps irratically. The up/down frequency changes are by a cube 1/2 inch square contactor. Its not optical. Just simple mechanical contactor. Remove the small cube from chassis and spray liquid gold. It will clean wire contactor and lubricate internals. You cannot buy the cube. Cleaning it always works for me. RF-B65 radio is a sure winner. Small, reliable and very sensitive. Has SSB also. eter
Sep 06, 2009 | Panasonic Audio Players & Recorders
Double cube fell and separated
Use a Flat blade screw driver to take off both grills. Take both speakers out use a phillips screw driver. Put your fingers in the cube with the protruding grommet, turn the object until you see it protruding its maximum. Next align it with the opening in the other cube and press until you here it click back together. re-attach speakers and put grills back on ..Whala!!!
Mar 16, 2009 | Bose Acoustimass 3 IV System
Ice cubes sticking together on ge modeltbx20tub
If the cubes appear to be shells, you have a restricted water supply to the refrigerator and will need to change the saddle valve where the 1/4" line connects to the house plumbing.
Dec 18, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Neurosmith Together Tunes Soft Musical Cube by Logo
78 people viewed this question
Top Neurosmith Toys Experts
Tom Chichester
Are you a Neurosmith Toy Expert? Answer questions, earn points and help others
