Question about Hotpoint Dryers
Hot Point Dryer won't dry, gets hot on top.
Less than a year old, drum works, goes through cycles, and the clothes do get warm, but takes forever for them to dry. The dryer itself gets really hot to the touch on top of the dryer. Filter is cleaned after every use, and I do small loads. Actually I noticed this after the 4 towels that I put in to dry weren't getting dry, so I reduced it to two. They're still not dry!
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
Check all the internal and external ducts for blockage.
Posted on Nov 07, 2012
    Top Expert:
  • 14,553 Answers
An educated guess would be either the lint tube or the tube that exhausts the air outside is blocked with lint----no airflow or greatly reduced flow will cause this symptom.
5 Suggested Answers
  • 63 Answers
SOURCE: Whirlpool Gas Dryer takes 2 or 3 cycles to dry clothes
did you check ALL lines..in and out for clogs!?
Posted on Mar 16, 2009
SOURCE: dryer gets hot but wont dry clothes
should the top of my 10 year old Maytag dryer feel almost hot to the touch
Posted on Oct 11, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore elite he3 takes wat to long to dry cloths
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Posted on Apr 21, 2010
  • 494 Answers
SOURCE: It takes forever to dry a load of clothes. Drum
Have you checked your vent for blockage? Over time, lint build-up in the vent and in the back of the dryer makes your drying time longer and longer. Unplug the dryer, pull it out and disconnect the vent. Using a flashlight and a vacuum, clean out the back of the dryer that connects to the vent and the vent itself. If you have a long vent line, you'll need to find a away to clean it out to clear any blockage. I use a hand-held plumbers snake that rolls up and pulls out as much length as needed. Then spin it around in the vent to knock off lint attached inside the vent tube walls. It may be easier to do this from the outside, but you can do it from the inside too. Check your outside vent cap for blockage and make sure the vent flap outside is not stuck closed. Also make sure when you push the dryer back into place, that you don't squish the vent tube, if it is made of plastic or foil. After reconnecting the vent, turn on the dryer. The air flow may blow out the lint you have dislodged with the snake. Clean out as necessary at the outside vent. I have a long vent line on my dryer, so I have do this annually. This has helped shorten my dry time every time I do it. Of course, cleaning out the filter regularly, does help too. The more often you clean the filter, the less lint that will build up in the vent . Hope this helps. Douglas
Posted on Jul 17, 2010
CLOTHES WONT DRY. IT GETS REALLY HOT INSIDE. THEY SEEM WETTER AFTER IT RUNS FOR AWHILE. TAKES PROLLY 3 HRS TO DRY.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 22, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer gets clothes hot, but forever to dry them.
I have exactly the same problem. My unit is 2 years old and has suffered this same problem since the day I bought it.
HELP
HELP
HELP
May 14, 2010 | GE Spacemaker Washer and Dryer Electric...
I just bought a gas dryer - takes forever to dry clothes
check the high limit switch/thermostat on the burner housing and if they are weak they will cycle the heat off too soon and it wont build the heat you have it set for,just bypass it with a jumper wire to test it,if this is the problem,dont leave it bypassed,replace it as it is a safety feature to prevent a fire
May 09, 2010 | Kenmore 95087 Gas Dryer
Doesn't get very hot
The only thing that will fail later on in the cycle would be your gas coils. They come with the gas valve on all LG's. But if your getting heat all the way through the cycle then I would check your venting and make sure its not restricted. This will cause long dry times. Hope this helps. _MJ_
Mar 26, 2010 | LG DLG3788W Gas Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Mar 15, 2009 | Dryers
Kemore Elite Oasis Dryer Error Code "AF?"
Problem solved! We read on here about someone else addressing the AF code by removing the back panel and fixing the pully that had come off. Belt was fine, with pully back in place dryer now works perfectly again. Thank you for saving us so much time and money!
Jun 14, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
151 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
