Question about Toshiba Televison & Video
Firmware till 42SL738N - Toshiba Televison & Video
Phillips BDP3000- blue ray discs plays till top menu then nothing happens. Can't play movie. Intro on top menu just loops
Please update a firmware just down load from Philips site and load in a USB pen drive and connect in BDP and run firmware upgrade option in a menu
Oct 31, 2014 | Televison & Video
Switch hub lynksys sg300 blinking
Normally its firmware issue update your firmware
Till you facing this issue means replace the antennas
Jul 20, 2014 | Linksys Cisco Sg300-28 Ethernet Switch -...
It has a red screen on it with wors i can't understand
Very Tricky...
If you have an Usb drive plug it into your computer and follow this steps
1) create a folder call PS3 Update
2) search for the latest firmware Ex ver 4.12
3) download the LATEST firmware and save it in that folder you made
4) turn your PS3 but hold power button till you hear 3 beebs(allows you to acces the menu)
5) Install the firmware and see what happens.
Not fixed let me know
Good luck and happy gaming-Koscoe
Oct 15, 2010 | Sony Playstation 3 (PS3) Console
How can we download and play psp games in version 6.10
Thank you for using Fixya!
Unfortunately with this firmware there is no way you can download a game (iso/cso) and play it with this version of firmware. The firmware 6.x I believe is still unhackable and you need to wait till developers comes up with a new version of Customer firmware that can hack this 6.x firmware.
Sincerely,
stif_nec
Jun 03, 2010 | Sony PlayStation Portable (PSP) Console
My psp games are not coming and the memory stick was not working nicely
the first problem you encountered was encountered by me aswell first you should know that all the games released in 2009 must have firmware above 6.00 so try upgrading the psp firmware to 6.00 and if you are using custom firmware try to upgrade to 5.50 gen d2 here are the links http://www.filecluster.com/Drivers/Firmware-Bios/Download-PSP-Playstation-Portable-Firmware.html for 6.00 http://pspslimhacks.com/custom-firmware-5-50-gen-d2-released/ for 5.50 gen d2 and for the memory stick problem try pushing the memory stick into the slot till the orange light goes off rate helpful
Dec 26, 2009 | Sony PlayStation Portable (PSP) Console
Turns off
Sir, try reinstalling its firmware or update its firmware.
Oct 02, 2009 | Coby MP-C7085 MP3 Player
Wrt150N loosing connection
It does sound like you need to upgrade firmware. Not sure what OS you are running as Linksys are still in the process of updating Vista firmware. Anyway here is the URL you need:
http://www.linksysbycisco.com/UK/en/support/WRT150N
Sounds like you need a firmware upgrade. Here is the URL
Feb 18, 2009 | Linksys Wireless-N WRT150N Router
How to Firmware/software upgrade on Razaor V3i?
yes you need to take the phone and have the firmware reflash on the phone to correct this issue...any mobile repair center should be able to get this done for you.
Nov 25, 2008 | Motorola Mobility RAZR V3i Cellular Phone
I have problems
belive me u will thank me later for thissss
u will not find any firmware for th10xx
so here is the solution that worked for me .. i had the same proplem
all u have to do :
hold on play/pause button and plug it in to your pc ,, keep on holdng that button till u find it recognized as recovery storge device or somthing like that !! ..
then u will find another icon in My Computer and Working
100 % :)
hope i 've helped as i kept on searching for help for 6 hours till i found de solution :D
Sep 09, 2008 | RCA TH1010 MP3 Player
Firmware upgrade
Firmware Upgrade Instructions:
Please download and unzip the firmware file to computer's local hard drive and then follow the instructions in the "readme.txt" file to upgrade the firmware.
Warning : -
Firmware upgrade failure may permanently damage the unit and causing it not to function. If the issues in the "Release Note" do not address the problem you are experiencing, please do not upgrade the firmware. Never upgrade the firmware using a wireless connection. Firmware upgrade will reset the Router to factory default state (all current settings will be replaced by default settings). When necessary, please write down the Router's current settings before performing the firmware upgrade. Please do not load the previously saved Router "configuration file" to the new firmware.
If you need assistance performing the firmware upgrade or if you have any questions, please contact our Techsupport Team http://www.trendnet.com/support.
Feb 16, 2008 | Trendware TEW-452BRP Wireless Router...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
