Question about Canon EOS Elan 7NE with 28-105 lens 35mm Film Camera
Film won't advance
The film is not always advancing after I take a picture. I've replaced the battery and tried diffrent film.
0 characters
1 Points
Everything seems to function well, actually, I've never used this camera. Got if off of ebay, so maybe I was gypped. Anyways, the film advance lever seems to be stuck. It only goes half way. I can put...
If the lever won't advance even when there is no film in the camera, then I would say there is a problem. (p.s. You haven't told us the make and model)
May 29, 2011 | Digital Cameras
Have a minolta x-7a that was in storage for a while - replaced the batteries - a little corrotion on the screw plate - installe new roll of will and can not get the shutter to activate so that the film...
you are having sensor problem in your minolta x-7a ..........since you have not used for long time it will better to put the battery and press the on button for 20-30minutes .......the sensor will function again
Jun 25, 2008 | Digital Cameras
I have a pentax 67 camera and the film advance lever is jammed. it will not advance without putting undo pressure on it which i am not willing to do. i have read many forums that have said this is not an...
Try pressing the film release button on the underside of the camera. This should unstick the advance roller.
If possible, replace the watch battery for your camera (inserted in the bottom, right by the teeny black button I mentioned above).
Change your exposure setting to Bulb exposure and back.
If all else fails, take your camera into the darkroom (or at least a completely light-insulated closet, bathroom, etc.), and pop open the back and recover your film. Hopefully you won't have too much wasted film on your hands.
Good on you, however, for not forcing the lever. Nothing good will come of that.
May 06, 2011 | Digital Cameras
When i try to advance my ae-1 camera it takes a picture! how do i fix it
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. ............or.
you can also try....
i'm not an expert on the AE-1. It is a camera I've never had any desire to own. But on most older slr camera the rewind knob will turn when the film is advanced. But only after the slack has been taken out of the film still in the canister. Since you've already taken a few shot the film shot be very secure on the take up spool. To check that it is, slowly crank the film rewind crank clockwise. After a few turns the film should become tight in the canister, and you will feel the tension. If this happens then the film was loaded properly. If after quite a few turns you still feel nothing, then the film was not properly inserted into the take up spoll. If the film was not loaded correctly the film leader will go inside the canister as you crank. But that is not a problem. Any photo lab can pull the leader back out. Just make sure they know what happened.
Mar 12, 2011 | Digital Cameras
We are unable to take any pictures
Could you be a little more specific? Is the film not advancing? Is the shutter not releasing? Do you have fresh batteries?
Mar 11, 2010 | Canon Elph Z3 APS Point and Shoot Camera
How to open a Vivitar 845 camera?
On the back of the camera, there are two sliders. The left hand one is the battery cover, and the other is the film back release.camera03a.jpg
Film advance is automatic when batteries are in it.
If this picture doesn't come out clearly, look at the ebay listing I copied it from ....,-CASE_W0QQitemZ380209378342QQcmdZViewItemQQimsxZ20100225?IMSfp=TL1002251310008r37318
Feb 28, 2010 | Digital Cameras
Nikon FG suddenly stopped working--not battery problem--help!
you should invest in a digital camera they have nice cameras for like 40 dollars on
Mar 18, 2008 | Digital Cameras
My camera won't advance the film
If it has not been used in a while, the batteries may be dead and/or the contacts on the cap and in the body may have corrosion build up. Try fresh batteries after you clean the contact points with an eraser. The batteries go in positive up, toward the cap
Mar 08, 2008 | Digital Cameras
Nikon D-100 Camera
Hi observe the flashing maybe late or advance. try to picture in the day light without and with flash compare it.
Jan 01, 2008 | Olympus Camedia C-50 Zoom Digital Camera
Canon EOS Elan 7NE with 28-105 lens 35mm Film Camera Logo
16 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
