Question about Pioneer AVIC-N1 Car DVD Player
Panel stuck in horizontal position with system operating
The panel moved to a out and horizontal position on its own and the display is not functional not getting restored
  • 26 Answers
We can fix any problem with the Pioneer AVIC. Please check out www.turbotunes.com for the best deals in your AVIC repairs.
-Steve
Posted on Apr 06, 2009
  • Bplagwitz Aug 20, 2011
    Turbo tunes is a complete rip off. Mr. kaner put rolled up paper on top of my flex cable and sent it back. When I asked him about this, he said this was common practice. Becareful
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Tip
SERVICE MODE AND POWER FL PANEL CIRCUIT
1. Main Functions
• Diag
Performs unit test of devices installed on the board.
• Display Error Log
Error log is displayed. Displayed contents can also be saved in an USB memory device.
• Factory Initialize
Restores the unit to its factory settings.
• Network
Checks the wired network connection.
• Version Up Not used.
• System Information
Displays the system information of the unit.
Displays information such as the software version, drive information, etc.
• EMC Test Mode Not used.
• Drive
Write drive OP data and check drive.
2. Menu Tree
3. Service Mode Menu (Top Menu)
This is the top menu of service mode.
Each function is accessed from this screen.
Operation:
[1] Moves to Diag screen
[2] Moves to Log screen
[3] Moves to Factory Initialize screen
[4] Moves to Network screen
[5] Moves to Version Up (DISC version update) screen (Not used)
[6] Moves to System Information screen
[7] Moves to EMC test mode screen (Not used)
[8] Moves to Drive screen
[9] Moves to HDD mode (Not used)
[UP]/[DOWN] Moves the cursor [ ENTER] Moves to the screen of the item selected with the cursor.
FOR MORE CHECK THE LINK ...
Electronics Equipment Repair Center
on Feb 14, 2015 | Sony Televison & Video
Why windows opens off screen?
Do youahev more than 1 monitor connected try
checking your display settings i fyou already have an OS installed or Horizontal position on your monitor. Occasisonaly a bios will have a screen setting too so worth looking her efor anything abnormal
Jun 24, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Memory seats adjust on there own as well as mirrors
BCM has nothing to do with this function , MMM - memory mirror module !
Memory Mirror System Operation
The MMM is capable of storing mirror position for 2 different drivers. Mirror position is determined by both horizontal and vertical position sensors in each of the power mirrors. The MMM supplies a reference voltage and a low reference to these sensors and determines mirror position through the horizontal and vertical position signal circuits.
The MMM receives power through the battery supply voltage circuit and the MIR/LOCK fuse and a constant ground source. Any time that battery voltage is disconnected and then connected from the MMM, the MMM will enter the mirror relearn mode. The mirror relearn mode can also be commanded using a scan tool. Refer to Memory Mirror Module Learn for further information.The memory switch receives power through the battery supply voltage circuit and the MIR/LOCK fuse. The MMM upon receipt of a memory switch signal input, a class 2 message from the SIC or a class 2 message from the PCM indicating that the transmission is in park, will then supply battery voltage and ground to the appropriate power mirror motors through the mirror motor control circuits to move the mirrors to the predetermined positions.
DTC B1586, B1596, B1616, or B1626
The mirror horizontal and vertical position sensors are potentiometers. The Memory Mirror Module (MMM) provides these sensors with a 5 volt reference circuit and a low reference circuit. The MMM monitors the horizontal and vertical position sensor signal circuits which change values based on mirror position. These voltage values are used to determine mirror position and can be set into memory. When the MMM receives a memory recall request, the MMM will control the power mirror to the memory position based on the horizontal and vertical position sensor signal values.
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Memory Mirror Module (MMM) data list.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Memory seat module
• Memory mirror module
• SEAT 25A circuit breaker
• MIR/LOCK 3A fuse
Your best bet , take it to a qualified repair shop !
May 23, 2017 | 2002 Cadillac Escalade
My computer screen is smaller then the monitor. There is about an inch of black surrounding the screen. It was displaying fine yesterday with my current set up but i had to do the factory restore thing and...
First make sure dispplay screen resolution is set to 1024*768 .
For that go to start ->control panel->display->setings set screen resolution to 1024*768 then apply .
If it is already set to 1024*768 then press menu button of monitor and increase horizontal and vertical position also put the picture in center first then increase both H and V position then it will give good display.
Also make sure display driver installed and working fine.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 03, 2010 | Computers & Internet
With my Vista Home Basic, How do I move the taskbar?
Hi goldenhead36
Right click on the taskbar and untick 'Lock Taskbar'. You should be able to drag and drop now.
Does this help?
May 09, 2010 | Microsoft Windows Vista Home Basic for PC
Microtek flatvision display horizontal continuous moving.
that is problem of diode near EHT that diode connected to big heat sink having three leads two series diodes in one diode replace it even meter shows ok .If persists then check mosfet irf 630 and path of its gate touch heat sink if it overheats then yoke is faulty replace it
Mar 17, 2010 | LG 500LC Monitor
Error code 000051
From service manual E051-0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
Action
1. Connector
Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected?
a. DC controller PCB (J304) <-> relay connector <-> horizontal registration home position sensor
b. DC controller PCB (J304) <-> relay connector <-> horizontal registration motor
NO: Connect the connectors.
2. Sensor lever (damage and interference), Sensor
Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation?
YES: a. The horizontal registration assembly is out of place because of
damage to the sensor lever. Replace the sensor lever.
b. The horizontal registration assembly malfunctions because of the
presence of foreign matter. Remove the foreign matter.
c. The sensor is faulty and cannot detect home position. Replace the
sensor.
3. Horizontal registration motor, DC controller PCB
Is the horizontal registration motor control signal generated by the DC controller PCB?
J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
YES: The horizontal registration motor is faulty. Replace the motor.
NO: Replace the DC controller PCB. Usually E 051 is the horizonal motor problem, you can take out the pick up ***'y. On the motor have a small gear, sometime this gear broken.
Or the horizontal reg motor became stuck in the wrong position. I was able to manually move it back and rebooted copier. Not sure why the motor was in the wrong position-cust related?
Oct 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
Error code E000051-000
E000051-000 is not a waste toner full error code thats E000015. This error code refers to the horizontal registration sensor not reaching home position or is not detected when the assembly is commanded to move. The sensors function is to determine the edge of the sheet of paper in the front to rear direction to determine the write position on the drum. It is not somthing you can fix and would require a tech. Possible sources of the error are, DC controller, horizontal registration sensor or actuator, or the horizontal registration motor. Based on experiance the motor is either stuck or burned out so the sensor does not move at start up
May 31, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Pioneer AVIC-N1 Car DVD Player Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
