Question about Carrier 38CKC036 Air Conditioner
How old is my armstrong a/c, model SCU10A30A-1A, SN: 8495A31798
JUST NEED TO KNOW HOW OLD IT IS.
Need part number for dual run capacitor for Armstrong Concept 10 air conditioner
The armstrong concept 10 comes in 7 different sizes. We need the model number off the outdoor unit.
Aug 08, 2017 | Heating & Cooling
Capacitor for 1300 concept armstrong A/C
Looks like a 35/5 mfd 370 VAC. TAKE A PIC BEFORE REMOVING OLD ONE. This way you know where tthe wires go
Jun 20, 2017 | Heating & Cooling
Need a wiring diagram for and armstrong SCU10A30A-3A AC unit specifically from the control board to the out side unit. not 24V to the contactors
Looks like all you have from inside unit to outside unit is the hot and common for the compressor contactor. What seems to be the problem?
Apr 12, 2017 | Heating & Cooling
Emerson TV SN: 011-40401078 Model TC1379 The power switch came loose and fell inside. I don't know if it broke or came apart. I only found the plastic piece and don't know how it attaches...
Well somtimes buttons break off of tv's because that they are old so its not worth fixing an old tv
now a days most people just buy a new one then instead of fixing the old one. Or you could find someone that fixes old tv's too. To find an old tv like the phiilps one we used to have you would probally need to go to an antique store or and a pawn shop or a secondhand store or a garage sale then. Or the dump because sometimes people put things in the dump like CRT tv's to get rid of them then.
Aug 22, 2011 | Emerson TC1351 13" TV
Remote control for Armstrong minisplit
You may be able to get any make of remote universal remote control and program it to operate your systems.
Mar 01, 2010 | RCA Universal Remote Control
Gas Armstrong Ultra V Tech 91-Is green light supposed to flash?
Installed a new filter and furnace is running great now. The old filter was not that old, but we have been doing some remodeling and I figure that is what clogged it so fast.
Jan 10, 2010 | Armstrong H 67 1PH Bf In Line Circulator...
Armstrong 4PHP13E36P runs after heating element cools
There may be pins on the circuit board inside the air handler that you can adjust. First turn off the breaker then look inside at the board. They may say 30-45-60-90 etc. Put the pin on a lower number. Do you have a digital or programmable T-stat? There may be a setting in the T-stat setup program that allows for blower delay also. consult you installation instructions. Last if the blower isn't turning off at all then the relay on the circuit board is stuck closed and should be replaced.
Mar 10, 2009 | Heating & Cooling
How to undo Child Lock
the key "POWER" +"TV/AV",
Oct 24, 2008 | Televison & Video
Carrier 38CKC036 Air Conditioner Logo
328 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
