Question about Whirlpool Water Heaters
My hot water heater will not ignite it stopped working overnite? its a whirlpool 50 gal model number BFG2J5040T3NOV
IT stopped working last night i tried to ignite this morning and it will not ignite, the igniter has a very faint spark it sparks where you can see it once or twice then you can't see it?
Sounds like the thermal couple may be shot I thought that was the problem with mine but it needed air to supply the burner I took the cheap steps first like working on a motorcycle or car I know that you can buy the whole burner with the thermal couple assembly, I got mine from a plumbing company it was used but in better shape than mine if its not very old it can be fixed I KNOW mine is working just fine!! Beware of the plumbing companies the will give up and try to sell you a new one to skip the grunt work really isn't as hard as it may seem!! What have you to lose???
Posted on Mar 24, 2013
  • Whirlpool Master
  • 5,089 Answers
1) Pilot is not igniting:
Clogged air intake.
Dirty combustion parts.
Bad igniter.
Bad gas control valve.
Air intake clogged caused overheated combustion chamber and tripped FV system and gas control may need replacement.
2) Product manual:
Read required maintenance, and troublehoot.
http://waterheatertimer.org/pdf/BFG2J5040T3NOV.pdf
3) Whirlpool water heaters have air intake located on bottom of unit, that can be cleaned from below with feather duster or compressed air.
Clean the flame trap as shown in illustrations following link:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Posted on Nov 07, 2012
mkh5094
  • 145 Answers
SOURCE: TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Posted on May 25, 2010
  • 21 Answers
SOURCE: Whirlpool energy smart water heater
Two flashes means that the high limit temperature has been reached. Once this happens, the temperature control system will shut off. Make sure that all element access doors are in place. Push the "Push to Reset" button to restart the temperature control system. The water heater will self test for ten minutes before it will start to heat. If you get the 2 flashes again then you may need to replace one or both elements. Each element should measure 5-25 ohms.
The "thermostat" is the knob marked "Temperature Control". Make sure that the operating mode is set to 1,2 or 3.
Posted on Jan 13, 2009
  • 21 Answers
SOURCE: Rheem 50 Gal Hot Water Heater will not stay lit
On the back of the gas valve (where you turn the temp up) there is a stem that actually goes into the tank that senses the temprature of the water it could be dirty or buried in sediment depending on how old the tank is, or just bad. if the tank is over 10 years old i wouldn't bother replacing the gas valve, the tank is probably not far behind. A new valve will run around $100.00 maybe a little less. You wont find it at menards or home depot in stock but they may be able to order it for you. Menards sells rheem products or try you local plumbing supply house. REMEMBER TO RELIEVE THE PRESSURE ON THE TANK BEFORE YOU WORK ON IT. IF YOU CHANGE THE VALVE DRAIN IT FIRST!
Posted on Feb 10, 2009
kevin000
  • 1847 Answers
SOURCE: Bosch tankless GWH 1600 H NG won't always ignite
The manual says to hold a match near the pilot while the ignitor is trying. It says that if the unit lights the pilot orifice may be dirty or clogged. Then the manual says to check the voltage on the igniter. It should be 1.3 volts DC minimum if it is not means the electronic control box is defective.
Let me know the status ...Kevin
Posted on Mar 29, 2009
gary1121
  • 332 Answers
SOURCE: Whirlpool Energy Smart water heater not hot
I think some one mis informed you, the normal temp on any water heater from the factory is 120, it should not go above that for reasons of sevear burns, as far as it't smart part it's just a name, you will lose a couple of degrees just comming torm the tank to the faucets, the water heater will allways keep the temp in the tank at what ever it is set at, it doesn't have the brains or computer to know what time of day it is but when the cold water comes in to the tank it comes thru a dip tube that goes to aprox 1 inch from the bottom of the tank, if you take a long shower and do not have a energy efficant shower head you can use up to 5 gals, per min of hot water where an energy efficant one only uses 2.5 or less and still has the same pressure at the shower head, the temp in your water heater tries to stay at the setting it is at depending on how much is used at one time meaning washing machine, filling tub or dishwasher at the same time, it lets more cold in as the hot goes out and as you know it can only heat up so much at a time and the cold water is just going across the bottom of the tank, so the name is just that no diffrent then any other water heater unless you went to a tankless water heater.
Posted on May 29, 2009
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
How do I bypass the control board on a whirlpool energy smart water heater ?
I run out of hot water after one short shower. Lights looks normal. I have adjusted it every way I can, still the 50 gal water heater runs out after one shower. I have check the elements and are fine.
Jul 07, 2012 | Whirlpool Water Heaters
Model 71-52DB 50 gal. water heater stopped heating
Press the reset button located on upper thermostat
Following link has troubleshoot for electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
Jun 13, 2012 | Rheem Water Heaters
Rheem RHEEM 50 GAL ELEC TALL Water Heater 1.5 yrs old, power at the elements, new elements installed new thermostat installed, still no hot water.
Hello Check the red overtemp reset button at the temp control.Check for contintuity at the elements with a volt meter (pull one wire off first) they should have a reading otherwise they are open & shot.Last is overdrawing (busted pipe) shut off the cold water supply for a 1/2 hour and open it back up and feel the hot water supply pipe.Is it hot?The tank can't keep up with the demand.
Sep 16, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
How do i clean out my system for my oil hot water heater? some how we ran out of oil, i guess we used way too much oil, it usually lasts until november but went out mid sept, i had oil delivered and now it...
It sounds to me like you probably have a clogged oil nozzle. Of course I'm am assuming that you bleed all the air out of the oil lines that run both to the hot water tank and the heating appliance. If you have solid flow at the water heater pump, and the unit still does not ignite, it is most likely the nozzle. Hope this helps
Sep 14, 2009 | RTO Bock Water Heaters 51E 50 gal 152,000...
Water heater- not always hot
common problems i have seen are:
1) wife or kids hitting the OFF switch thinking its the light switch in the closet where my heater is located.
2) heating element has died. you should have 2 elements in this heater. when one dies, the heater cannot keep up with the demand of heating 50 gals of water.
if there is a warranty, then now is the time to exercise it.
if no warranty, then it is possible to troubleshoot each element to see which one is dead if you are handy with a voltmeter and electrical wires. if comfy, i can provide steps to narrow it down. list the kenmore model number if you reply.
Feb 02, 2009 | Intermatic WH40 - Water Heater Time Switch...
Water Heaters Logo
620 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
80stech
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
