Sony mhc s3 cd player tray not opening - Audio Players & Recorders
SOURCE: Erratic CD tray behavior on SONY MHC-881 Shelf system
change cd head
Posted on Nov 27, 2007
  • 3 Answers
SOURCE: Everytime I try to open the disc tray it flashes either EX-Change or mechanical error and won't open
I have a Sony MHC-GX555 stereo and every time I try to open the disc tray it either flashes EX-Change or mechanical error and it won't open.
Posted on Jun 18, 2009
SOURCE: sony mhc-mg310av cd changer wont release cd
Check if the tray got a belt and change it
Posted on Oct 02, 2009
  • 61 Answers
SOURCE: how do i open the cd tray on a sony mhc-rg70av
Most CD trays will open if you shut off equipment and pull gently but firmly to overcome the slight initial resistance. Don't use so much force that it seems likely that the tray mech will break. This calls for a serious bit of taking apart and is best left to the local repair shop.
Posted on Oct 31, 2009
ETRONIC
  • 62 Answers
SOURCE: sony mhc-gx450 cd player is not reading.I used a cd cleaner and d
First unplug the unit and press the power button to make sure all the power is out of the unit. Try to take a cotton qtip and clean the lazer lense with alcohol. after wipe it clean with a new cotton qtip to remove the film the alcohol produces. Do not use a lot of alcohol and drip it all inside of the unit though.
Also if you tried a cd-r try a real copy instead. Make sure your cd's are ok.
Good luck.
Posted on Feb 16, 2010
I have a Sony MHC-771 mini stereo system with a 3 cd disk tray. I need to replace the belt that operates the cd tray? The tray is stuck in the closed position. Any suggestions?
Remove the belt and measure it in MM. The search for a belt at that size with Google. You don't have to be too precise about the size. For example if it is 48mm than a 50mm belt should do the trick. Don't bother with the maker's name either. Then can be universal. As long as it looks right.
Jan 30, 2017 | Sony MHC-771 Shelf System
Sony mhc s3
check connections and media
Jan 14, 2014 | Audio Players & Recorders
Sony dvd player mhc-gn1200d is the model. placed cd inside then a message appears "please wait" but nothing is happening. umplugged and plugged it, same message appears and cd tray won't open. what will I...
Sounds like you'll have to use the manual release to open the tray.
Turn the unit off.
There should be a small hole just under the tray, unbend a paper clip and push it in the hole, the tray will come out part way, it can then be pulled out by hand to retreive your cd.
Reclose the tray and turn on the unit. If it now functions normally, the problem was most likely the cd, but I would still use a laser cleaning disc just to make sure the lens is clean.
Oct 03, 2010 | Sony Televison & Video
CD Player does not always recognize a CD in the tray.
1) The CD may not be in a compatible format, check against you system instructions.
2) Run a CD lens cleaner for a minute or so.
Mar 24, 2010 | Sony MHC-RXD7AV Shelf System
I need then service manual for my Sony GENEZY MHC-GT555. I must clean the cd lector.
I used a long wooden stick and put a peace of cotton in one end (weeted with tap water, just moisted).
Then I introduced it through the open CD tray and wiped the sensor twice or three times.
It worked OK.
Hope it can help.
K.R.
Feb 07, 2010 | Sony Audio Players & Recorders
How do i open the cd tray on a sony mhc-rg70av shelf system that seems stuck
Oct 31, 2009 | Sony MHC-RG70AV CD Shelf System
Sony VGN-T350
hi , please be specific, is the tray not opening, or there is a NO DISK error???let me know,
Dec 30, 2007 | Sony MHC-881 Shelf System
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
206 people viewed this question
 Grubhead
Grubhead
