Changed bulb on my sony srd projection tv but still won't come on
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Look first to make sure lamp was installed correctly---which light on front of set blinks---look for it to blink in a sequence of say 5 then pause and repeat--a error code is indicated.
Posted on Nov 07, 2012
welcomejee
  • 10594 Answers
SOURCE: Sony KDF - 50E2000 Projection TV Lost Brightness control after replaceing bulb
Let me know have you adjusted Lamp Replacement option in Menu > Settings in TV?
Posted on Oct 04, 2008
ladywinn
  • 5138 Answers
SOURCE: sony kp-51ws520 what bulb does it take
Tube numbers on tubes.Red Green Blue?
Posted on Dec 25, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Posted on Oct 17, 2009
johnnydiode
  • 647 Answers
SOURCE: Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Posted on Oct 24, 2009
Testimonial: "Many thanks to johnnydiode and all the others on this site sharing their knowledge and providing a valuable service."
SOURCE: Sony Projection TV bulb replacement
how to replace bulbs KDP-65XBR2 65 sony
Posted on Oct 22, 2010
I have a sony KP5375 TV and the screen flashed and went dark. Now it won't turn on and there is a electrical smell coming from the TV. Reset doesn't work. Does this sound like it is more th
yes bulbs dont smell unless they pop plus its 3 bulbs in there, plus the tv would still have power/standby lights, and it's not that type of smell, replace the bulb but im sure this will not fix the problem, also my experience with dlp set it is often not worth repair, good luck you need more help or question just ask good luck
Mar 30, 2013 | Sony KP-53S75 53" Rear Projection...
My sony wega tv won't turn on red lamp light blinking whats wrong??
The bulb on the.tv.may be bad as.well as the color wheel try replacing both
Dec 18, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a 2006 Sony KDF-55-E2000, just replaced the lamp and housing and now I have a green stripe at the top and a red stripe at the bottom. Is it worth having this set repaired if I do not have an ex
We had the same problem. Let it be and now the tv won't turn on. If I understand correctly from what I've read it's the optical block and they seem to be just as much as a new tv.
Jun 23, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
I have a Sony rear projection tv KP-57HW40 won't
Follow the power cord (set unplugged) into the set as it goes directly to the main fuse (should be 6.3 amp) and see if it is good or bad.
May 16, 2012 | Sony Televison & Video
Sony srd shut off
Double check to make completely sure the lamp went in perfectly--even experts sometimes do not get it in correctly---also if set not coming on what lights are blinking on front---the red one should blink a specific number of times indication of error code.
Apr 22, 2012 | Sony KDS-R50XBR1 50" HDTV
Sony rear projection lcd hd tv 46 inch...the replacement bulb indicator popped on ....i bought a bulb but haven't replaced it yet. now i see a 1 inch rainbow strip across the top of the tv. from end to...
Replacing the bulb won't fix this problem. This is a defect in the optical block, which is apparently fairly common.
The best way to get in contact with the team that can fix this problem is by facebook. While on facebook, type "I have a defective Sony TV" in the search bar. This will bring up a page that is moderated by the SonyListens Team.
Post a comment about your TV, be sure to list your model number and a description of what's wrong with it. Someone within a few days will give you more information as to what steps to take next. It will seem like a lot of hoops to jump through, but in the end will be worth the time it took, as Sony will offer you huge discounts on a newer TV (I recently went through this, and got a new 3D ready TV for about a quarter of it's suggested retail value). If you are not on facebook, they list a contact email address as SonyListens@am.sony.com
Also worth noting: if you have receipts for recent repairs or replacement bulbs, you can submit them along with the other info, and Sony should adjust the offer price to compensate.
One word of warning though, once you have started this process and have received an offer from Sony, you will only have a week to claim the offer, so make sure you have the funds to put down on a new TV before you start.
Hope this helps! :-)
Jun 22, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
I have a LG rear protection tv. I believe 52sz8d-is. When I plug it in the red power led light comes on and the bulb led flashes green but it won't Turn on
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
Jun 05, 2011 | LG RU-52SZ51D 52" Rear Projection...
Tv is on 'stand by' & won,t turn 'on' &
I will need the model number of the set and also need to know if the led blinks. If so how many blinks does it blink?
May 29, 2011 | Sony Televison & Video
Changing bulb
Changing bulb in Sony KDF-60XBR950 is easy.
Click Sony Support to download lamp replacement instruction manual for your TV.
Please buy Sony original lamp/ bulb for your TV safety.
Thanks.
Dec 29, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
New HDTV bulb
I have just bought a second hand Sony 50 inch Projection & the owner from new (paid 1200 Quid) assures me he has never replaced the bulb in 6 years. Don't pay 190 Pounds plus, if you can loosen 2 nuts you can get an Osram bulb alone (not mounted) for 32 Pounds 55 Dollars delivered if you search well on E Bay
Jul 29, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
