My computer sounds beep when switched on
Whenever i switch on my pc ,,theres a sound of continous beeps and doesnt start up
  • joecoolvette
    joecoolvette Nov 07, 2012
    Computer unplugged from power, FOLLOW Anti-Static Precautions. Clean the inside of the computer out, and the Power Supply the best you can; with a can or two of compressed air for computers. Remove ALL ram memory module/s, and clean the gold plated contact pins with a pencil eraser. Let me know what happens in a Comment when done.
    Master:
  • 545 Answers
Your RAM has wiggled loose. Remove it and reseat it.
Posted on Nov 10, 2012
SOURCE: ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Posted on Nov 20, 2008
ebay312
  • 118 Answers
SOURCE: no sound on computer, no beeps and no talking on videos
The good news is that driver detective should be easy enough to get your money back, but you'll most likely have to wait days or weeks to see it again.
As for the sound, Did the computer ever play sounds? Dell has a relatively easy to navigate driver download system on their website. You'll need your Service Tag (S/T) number to get the most correct driver.
If you follow this link, then click on Enter My Service Tag, it will take you where you need to go get drivers for the Dell.
you will need to have Flash installed on your computer for the website to work. You can download that free if you do not have it at www.adobe.com
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
good luck
tony
Posted on May 23, 2009
  • 6 Answers
SOURCE: beep sound continus
I went to google and it seems like the beeps can be problems for different problems in the hardware, this is what one message says,  there are lots of computer beeping answers out there: 1 short beep is your BIOS saying "HELLO I'M OK"
Standard Original IBM POST Error Codes
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps keyboard card
Each BIOS company has modified these codes over the years.
Posted on May 25, 2009
  • 63 Answers
SOURCE: no picture and desktop makes beeping sound
Base on the post codes this continuous beeping indicates a power problem. Atypically this is a power supply problem and it will need to be replaced.
Posted on Oct 06, 2009
mace1mace
  • 1138 Answers
SOURCE: high pitched beeping sound?
hi!
I'm not sure with your beep code.. but here is the list of known beep codes for dell motherboards
Beep codes Possible Causes Solution
1-2 no video card detected Reseat the video card
1-2-2-3 BIOS ROM checksum error
1-3-1-1 DRAM refresh error Reseat the memory card
1-3-1-3 Keyboard error Keyboard connector
1-3-3-1 memory card Reseat the memory card
1-3-4-1 RAM failure on line xxx Reseat the memory card
1-3-4-3 RAM failure on data bits Reseat the memory card
1-4-1-1 RAM failure on data bits Reseat the memory card
I hope it match your beep code..
Please rate this help.. thanks..
Posted on May 25, 2010
My whirlpool white magic 650 P produces contineous beep sound while connected to the electric plug. However the power switch and light indicators on the mechine is not working.
Sounds like you have a control logic issue. Either a button on the control panel is stuck, or the control board is defective. Find the model number on the unit and post it in the comments please.
Jan 11, 2015 | Whirlpool Washing Machines
Beeping wheneve the switch on the system
Try http://www.computerhope.com/beep.htm first to find out which component is failing. If possible, take the cover off & reseat everything you can see. If all else fails, take it to a computer shop.
Jan 23, 2014 | HP CTO HP Workstation XW6200 Base...
Continous beep sound from the mother board
make sure your cpu fan is runing and the psu fan is running if they are then it maybe your computer ram
Feb 28, 2013 | Dell OptiPlex 760 MT Desktop Computer
My laptop makes a continous beep sound and doesnt start till i do it by pressing esc key..?it doesnt start auomatically.
first you replace your ram or check it if on then oky if you have 3 beep then you have display problem you pulg the cable of moniter and press the key fn on change moniter display if display you lcd filament problem its change able if not display then your vga chip heat up so its not have proply solution
Dec 27, 2010 | Compaq Presario 700 470024-192 Notebook
Not sure if it is MB or CPU when i try to turn on computer the only thing that happens is i hear a beeping sound. beep...beep...beep... continually. it wont go to the post, nada. the fans run and i have...
Continous beeps usually mean the motherboard or the power supply, Try another power supply first and see if it will boot, if not the motherboard is faulty, if the prossesor was faulty you would no beeps the fans would run but nothing on the screen. hope this helps.
Aug 24, 2010 | Computers & Internet
My laptop has starting prolem ...when i am switch it on ... it is starting with contineous sound of beep....and also my touch pad mouse is not working some time properly... i had format it two times with...
Hello, hetul58519
I installed some extra memory on my PC, didn't do it quit right and recieved a series of beeps untill I fixed what I had done incorrectly during the install. The beeping is the computer way of telling you something is not right, it is trying to audibally tell you what that is. Now, it is up to you to search for the hidden meaning behind the continuose beep. Do a search for "computer beeps" or "computer audio cues". Do you recieve any warnings other then the beep? Is the computer acting funny in any other way?
Aug 13, 2009 | HP Compaq Presario CQ70-120US Laptop
CPU power problem
Check whether all connection are good and take out any CDs in the tray. I guess this must be a SMPS problem.
May 11, 2009 | E-Machines (T2958) PC Desktop
Doesnt switch on
You said buzzing sound is this more like a beep? Beeping sound are indicative of any number of diagnosable issues, depending on the actual number of beeps and the type of motherboard.
Sep 28, 2008 | Compaq Computers & Internet
Continous Beeping sound
Hi neosw,
Could you provide a little more detail?
Was this a previously working set-up or is this a new build?
If this was a previously working set-up have you changed anything?
When you switch on the PC
  • do you see anything on the screen, does the monitor remain in standby?
  • are any of the fans running?
  • does the hard drive spin up?
  • does the beeping sound stop after a short while?
The reason I ask these questions is because a continues beeping usually means that the BIOS is not seeing the processor, or that the power to the processor is not correct. With some BIOS manufactures it can also mean the processor clock speed is not set
correctly.
Please don't take this the wrong way but...if you provide greater detail in your question, the easier it for us to diagnose your problem, otherwise we can only make educated guesses.
I hope this has been of some help.
Regards,
Spare head 2
Jan 06, 2008 | Soltek SL-K8AN2E (SL-K8AN2E-GR)...
Monitor did not responding
When you first power on a computer it checks itself out for proper operation even before you see anything on the screen. This process is called Power On Self Test, as no video is yet displayed and moreover there may even be a video problem the computer sends out beeps over its internal speaker to indicate its status. Usually you will just hear one beep then the computer will "come to life", if however there are any problems you hear a series of beeps. For a description of these beeps and what they mean please click here. Hope this helps !!
http://www.customautomaticsystems.com/ShowArticle.aspx?ID=54
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
