Question about Kitchen Ranges
After cleaning the drip pans don't align up correctly
Normal electric stove top. and they don't align up like before, they stick out and are tilted uneven.
  • bluecarlito Jan 05, 2009
    solution: you need to put the drip pan first then put the round circle one on last. if the round first then the pan is done it won't fit properly.
5 Suggested Answers
appldoctom
  • 311 Answers
SOURCE: Stove Top won't heat
clock works because its only 110 volts.all else is 220.as a repair man the firstplace i would check is the cord.[power off]why there first the installers dont know how important it is for those cord screws to be very tight.consequintly the leave them looseish,and thats where they burn.if thats ok.make sure you have 220 there at the cord.God bless you,tom
Posted on Jan 02, 2009
SOURCE: How do i clean my flat stove top electric stove
There is a special solutiun to clean electrc stoves
Posted on Jan 18, 2009
  • 360 Answers
SOURCE: The metal drip tube that is situated from the top part of the
if you remove the tube, it can be gently heated with a torch and the grease allowed to run out, after which, pass large amounts of hot hot water through the tube. to clean without removing, I find a speedometer cable works best to get a path through the pipe, then again, large amounts of hot hot water to flush out/clean the pipe
Posted on Feb 13, 2009
  • 82 Answers
SOURCE: Back burner caught fire
If the water has been dried up, it was most likely the drip pans. Water is non flammable, sorry i couldn't help myself. If water was the problem there would be sparks and buzzing noises first.
Posted on Jun 18, 2009
I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
Mar 13, 2017 | Whirlpool RF263LXTQ Range
Need to replace the burner on my stove
TURN OFF POWER. LIFT BURNER. REMOVE DRIP PAN. BURNER SHOULD PULL UP OUT OF HOLDER. TOP LIFTS UP IN FRONT TO CLEAN & ACCESS.
Oct 21, 2009 | Whirlpool RF364 Electric Kitchen Range
Amana AP095R Portable Air Conditioner is dripping water constantly. It didn't use to do this. What's wrong here?
all air conditioners condense water .. the water is normally drained to the outside thru a hole near the outside bottom of the unit .. the unit has to be mounted so that it doesnt tilt inward .. the drain hole has to be cleaned once in a while ... if its clogged or if the unit is tilted inward then the water will drain inside the house .. less likely but possible is a cracked or damaged drip pan inside the unit ... thats a shallow pan under the condenser (cold) coil that captures the water and directs it toward the outside drain .. so check the tilt and clean the drain
Aug 17, 2009 | Heating & Cooling
Jun 17, 2009 | Kitchen Ranges
KGCS1340P stove top -- I need burner drip pans. Source for parts, please?
I'll be glad to sell you one. I have the same model and am ready to replace it with a new cooktop. I have the same KGCS1340P but can't find part under the knob.
May 18, 2009 | KitchenAid Kitchen Ranges
When using the oven or especialy the broiler the outside of the stove (the part where the control panel is), right above the burner gets extremey hot so hot if you would touch it you would get a severe...
There is a vent pipe for the oven in the back usually just under the left rear burner, it is normal too get hot air there, if your drip pans are all solid you might want too change too pans that have holes in the center it should allow the top too breath a little better.
Jul 30, 2008 | Maytag Kitchen Ranges
Smoke from top of stove
no it means that what ever spilled on the elemnet drip pan has not completely burnt itself off. replace the drip pan at first chance you get
Mar 23, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
