Question about Sunon 25x25x6mm DC 5V Magnetic Levitation Fan (13000 RPM) Fan Kit
I am looking for a cooling fan...these are the numbers..i don't know what they mean so I will give you all the numbers.... A power PS705M2B DC 5V F149618 04234011MB The second fan is a small one.... 040517KA DC 5V 0.16A YD05 25R DC Brushless Fan
I did not fix the problem yet...But I don't need a repair plan I just need the fans...This is what I am shopping for..thanks for getting in touch with me.
Posted on Jan 05, 2009
Micromax x225 is showing low signal
Ever looked at the power specifications of a mobile charger?? well if not, then have a peek... u will read that the output voltage is 5V DC........ the computer USB also has a voltage output of 5V DC........... any USB based electronic device needs this power to get started.... The laptop coolers u get basically work on this power from the USB... U'll notice that the USB ports have 4 terminals.... the extreme outer side are the POWER terminals +ve and -ve..... the middle 2 are the BUS lines IN and OUT.... a BUS is something electric conductive that allows the flow of 0's and 1's or rather high and low voltages to pass(Basic IT theory).... so this 5V DC can be used for doing anything; charging the mobile phone battery to lighting up entire rooms with LED's, making laptop coolers, etc......... Every mobile phone which has the USB connectivity option gets charged when plugged in... so sometimes even if u dont have the Mobile charger dont panic, find a computer and plug in the USB... not only micromax x225 mobile but, there are almost 80% mobiles which charge by connecting it to pc. Only nokia phones don't get charged. it is a good feature don't worry
Feb 24, 2012 | Nokia Cell Phones
Xerox 7300 DN color printer, I am getting an error message "Fuser Fan Failure" reference code U32. What does this mean, How do I fix this? Do you know of any people who service printers in the...
It means you need to replace the fuser rear cooling fan the part number is 116-1024-00. New it is about 100 dollars you can find a refurbished one for 35 to 40 dollars. I am sorry i dont know anyone the the dc area that services printers.
Apr 19, 2011 | Xerox Phaser 7300DN Laser Printer
Dear Sir, I have astec model AA23160 power supply input Ac 100-240 5A max output Dc +5v 23A, +12v 22A max it does not give output the LED give yellow when it is ON. the two cooling fans were also not...
Hi! l have have the same problem whit the Asctec model AA23160 power supply.But l need to know how many time your power supply worked: How many time do you use it?
Thank's!
Aug 13, 2010 | Astec 300w AT Power supply 190170-01...
Will not boot up
I have seen a lot of Toshiba Laptops with bad "DC Connectors" on the motherboard. It sounds like you know what your doing so here a link on how to disassemble your laptop.http://www.irisvista.com/tech/laptops/ToshibaM2/tecra_M2_disassembly_1.htm
and here is another on how to repair the dc connector. http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
May 27, 2009 | Toshiba Tecra M2-S530 Notebook
Cooling fan replacement for my hp 6624A dc power system
TAKE 9VOLT BATTARY TO SEE WITCH WAY THE AIR BLOWS, UNLESS BY LOOKING AT THE POWER SUPPLY HOUSING AND UNDERSTANDY WHAT THE ARROWS ON THE CACE SHOWS DIRECTION,
DO YOU HAVE VOLT METER, YOU NEED TO TEST TO FIND OUT OUT WHAT 12VOLT + OR - IS ON THE POWER SUPPLY , SOMETIME FAN MANIFACTURE WILL GIVE A CABLE TO PLUG INTO YOUR POWER SUPPLY TO MAKE YOUR FAN TO OPERATE THE RIGHT WAY, IF YOU NEED MORE HELP WITH THIS YOU CAN CONTACT ME THREW THIS SITE
CANDYMANGANDY
Jan 27, 2009 | HP (D6021-63034) Fan Assembly
Konica minolta 1216
1. A fan irregularity signal, excessive current draw due to binding. Examine M4 for obstructions which may bind the fan. Check the M4 fan lock signal (main CB, CN26-4) in the 47 mode, input code 42. The voltage should be between 0.1 to 0.2V DC. If 5V DC is present, either the fan is binding or the fan is defective. Replace M4 (p/n 25HA80512).
Note: If the fan lock signal is normal, install the version 17.0 EPROM (p/n 101517-17.0) to prevent false F54 errors as outlined in 1015/1212 Technical Bulletin #15.
2. IC7 on the main CB has shorted due to a failed total counter. IC7 shares the 24V DC control signal line with the exposure lamp, separation solenoid (SD1), registration solenoid (SD2), total counter, key counter, and cooling fan (M4). All loads except the total counter operate in diagnostics.
Replace the total counter (p/n 466088201) and the main CB (p/n 25HE-7312).
3. A poor connection between the cooling fan (M4) and the main CB. Reseat CN73 at M4 (cooling fan) and CN26 on the main CB.
Dec 19, 2007 | Office Equipment & Supplies
Pc is not starting up
I'm sorry to tell you but your cpu has probably fried. Your pc hanging a lot probably meant something was overheating and the fact that you say your cpu is not hot when you have the cooling fan off of it means it is probably the cpu. When you first turn your system on without a cpu cooling fan, the cpu should be slightly warm, although I do not recommended running a cpu at all without a cooling fan or even touching it when it has power.
Aug 18, 2007 | Intel Pentium 4 1.7G, 1.7 GHz...
Sunon 25x25x6mm DC 5V Magnetic Levitation Fan (13000 RPM) Fan Kit Logo
157 people viewed this question
Top Sunon Computers & Internet Experts
David Payne
David Payne
Are you a Sunon Computer and Internet Expert? Answer questions, earn points and help others
