Question about Kenwood KENCJ99SSA Microwave Oven
NO HEATING NOT HEATING
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
Microwave not heating up
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Sep 06, 2008 | Microwave Ovens
Microwave not heating food
HI>if the problem of your oven is the heating then the problem would be on the heating filament that is MAGNETRON.It is a filament that is responsible in heating the oven.It is actually a square shape-type accesorry that can be found inside the oven's circuit.If this accessory is defective it would defer the unit from heating.Thank you for choosing FIXYA.
Jul 23, 2011 | DeLonghi Microwave Ovens
Our American ADW1100n15BB dishwwasher does not have any hot water.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
May 05, 2011 | Microwave Ovens
Diswaher will not dry heating does not work
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dec 05, 2010 | Microwave Ovens
Hi, My slim line bosh dishwasher has stopped heating the water. can you tel me what the problem could be and would it be expensive? Thanks Mandy
A bad heating element causes many problems in dishwashers…
heatman101
Sep 04, 2010 | Microwave Ovens
Dishwasher is running through cycles ok but water is not heating so only cold cycles.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element formineral deposit on it, clean the deposits using a soft brush and a cleaning solution(Don't scrub the elemnt hard). If this doesn't resolves the issue then remove the panel and examine all the wirin connections to the heating element. Now, use a multimeter and check for the resistance reading(ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue.
Thanks
Daniel
Aug 07, 2010 | Microwave Ovens
MW1030WA 1000 Watts Microwave Oven: Not getting full heating effect. Heating effect re...
If there are no bangs or arcing taking place and simply the heating output is slow, then it would be a matter of replacing the magnatron. Once the micro cover is removed,the magnatron is that square module sitting half way up bolted on with 4 small screws. Quote the model on the sticker stuck on the MAG. and order a new one. Take care when replacing. Lage voltages present on capacitor.
May 18, 2010 | Samsung MW1030WA Microwave Oven
The Magnetron has stopped working in this case and, you will need a replacement Magnetron heating device. this will fix your heating issue.
Replace the Magnetron. Runs about a 160.00 or maybe cheaper in most cases.
May 30, 2009 | GE Microwave Ovens
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
Kenwood KENCJ99SSA Microwave Oven Logo
Top Kenwood Microwave Ovens Experts
John
Are you a Kenwood Microwave Oven Expert? Answer questions, earn points and help others
