Question about Konica Minolta Bizhub C350 Digital Copier, Printer, Scanner With Mail Box 350 C
How do I print 5x7 prints on my Konica Minolta BizHub c350 printer
Do I setup a custom paper size and use the feed on the side of the printer?
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
firecontrol7
  • 6161 Answers
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Posted on Jul 25, 2009
SOURCE: Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Posted on Oct 15, 2009
Bizhub C350 envelope problem
Load the envelopes in the bypass tray select paper on the copier control panel select by pass tray change tray select normal DO NOT select envelope select custom enter size, on printer preference select envelope tray and print
Apr 18, 2012 | Minolta bizhub 200 All-In-One Printer
How to print onto smaller paper
Under printer setup select your print, then change the paper size in the settings to the paper you're using.
Change the alignment of the paper feed on printer to the size of the new paper
Feb 21, 2012 | Konica Minolta bizhub C250 All-In-One...
Hi can a Matching paper size is not available cause a printer konica bizhub c350 to be offline?
If your copier is connected to your network and you get this error, the answer is no. If you are getting the miss match error then the print job could be stuck in the que. This would cause it not to print. If you dont know how to clear the print job, restart your computer and try to print again using the correct paper size.
Mar 08, 2011 | Konica Minolta DiALTA Di183F Copier
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
My Konica Minolta bizhub C250 seems prints about every 10th page crinkled and crooked. I can hear it going through the machine and crushing a crease in the paper as it prints. The printed also seems to...
The paper may not be feeding straight out of the paper tray due to poor stacking of the paper in the paper cassette. try another paper tray or check the paper in the paper tray for folded over papers usually near the bottom. Also try feeding paper from the hand feed tray on the left side. This uses a different paper path.
Dec 07, 2010 | Konica Minolta bizhub C250 All-In-One...
I am trying to print from my computer to the konica minolta c350 but i can't get the paper size right. How do i fix the settings
Very vague. but make sure the dial is set right on tray one to match the setting of your driver. (media type not size, but 8.5X11 thick 1 is not the same paper as 8.5X11 thick 2. The machine will tell you exactly what size and type you have requested of it. Simply Make the drawer match.
Jun 04, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
May 11, 2009 | Minolta C350 Printer
Konica Minolta Bizhub C350. Precut 4x6 full bleed postcards.
Hello
Yes, there is no 4x6 choice, you have to input costume size.
For the bord-less part, i first would recommend to use a little bigger costume size so if paper with is 20 mm and there is a boarder about 1-3 mm then input costume size 23 mm. Caution, this can cause a paper jam, because there is a solenoids, what read paper. or you can use a bigger paper and later cut off the boards. Because this printer is not capable printing board-less photos
Jan 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printer & scanning Driver for Konica color 8022
I believe that machine uses the same print controller as the Bizhub C350. You will have to verify this - it's an optional unit attached to the rear of the machine. It will be where your network wire plugs in. It "should" be a IC-401 model print controller. That's the driver you need from Konica.
Feb 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub C350 Digital Copier, Printer, Scanner With Mail Box 350 C Logo
170 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
