Question about Sylvania SRPD442 42 in. EDTV-Ready Plasma Television
SRPD442 TV WILL NOT DISPLAY PICTURE AND WILL NOT SHUT OFF
Hello, I have a Sylvania SRPD442 Plasma that is giving me trouble. I purchased it from my brother so I have no warranty. The first problem I have is I only have one of two possible working bank of component inputs. I have been using the working one to hook it up to my cable box. The next problem I have is intermittent, perhaps once a week. I'll turn the tv on and I'll get a picture and then it will flicker and go out. When I go to turn it off, I push the power button and it will not shut off. I'll unplug it and wait a couple of minutes and then replug the power in and click the power on and no I get no picture and once again it will not shut off. I tried using the remote control and it will not shut it off either. However, when I try it the next day it will work. A week ago I opened it up and pushed on all ribbons and blew it out with a can of compressed air. I put the back on and replugged it in and it worked. Now....same deal. Also do you know what a fair price is for service of this tv/problem? Hope you can help, Regards, Joseph Mikulas
    Genius:
  • Sylvania Master
  • 1,690 Answers
This can be many types of faults. The set will need shop service. There may be cold solder connections on one or some of the boards, or there may be come components that are intermittant. In anycase most of the time, there will be the need for board replacments.
The cost for this type of repair can be fairly expensive. I would consider investing in to a new set because after having this serviced, there will still be many older components in the set that can potentialy fail.
Jerry G.
Posted on Apr 18, 2008
SOURCE:
When you start light turns green but go's back to red . sylvania 6842thg
DOES THE TV STAY ON ??DOES IT TURN OFF?...MOST CASES IS A FAILURE IN ONE OF THE POWER PROCESSING BOARDS..WHICH MEANS THAT HAS TO BE REPLACED..
Mar 18, 2011 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Is my ILO 42" "EDTV" plasma ready for just a regular antenna?
No, it doesn't have a digital tuner. If you want to watch digital channels you will have to acquire a digital set-top box and connect it to the tv thru the av inputs.
Jan 16, 2010 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
I have a Sylvania 42 inch Plasma HD TV. It is 3
Hello
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Sep 24, 2009 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Sylvania 42" LC370SS8
Your TV monitor cannot support the format (scan rate) that your computer's display card is putting out. Go in to the computer's set-up for the resolution under the display properties and adjust the settings to support the TV monitor. Refer to the TV's instruction manual to see the supported formats.
When going back to the computer's display, the display format will have to be changed back to have the proper resolution.
TV sets are generaly not as good as dedicated computer monitors for use on computers.
Jerry G.
Apr 18, 2008 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Ilo 42 inch plasma display tv
tot2523, your on off switch needs to be replaced. We have one, and we are now on our 2nd repair of the switch. First one blew and now the power switch won't go on. It seems it is a flaw with this t.v. Our t.v. is only 2 years old.....
Jan 14, 2008 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Sylvania SRPD442: picture has lines and particles in it, can't make picture out
The fault can be the screen itself, or one of the driver boards for the screen. This has to be verified by trying the boards.
I don't know for your model if the backplane lamps can be replaced. In most of the models they can be.
Jerry G.
Nov 21, 2007 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
in this model, the ribbon cable conection fail many times, and tis sound to be the problem, just open it and secure all sokect conection better get a tech to do it ...good luck
Aug 09, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Sylvania SRPD442 no picture
Your problem is probably in the power supply as theres a voltage called the sustain voltage that is always keeping the screen charged so the address lines will activate the screen and make it light up Via the Microprocessor and the video processor. This is not a repair for a handy person as this set, you can cause more problems Please seek out a trained tech for this set. Good luck
Jul 24, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
TV goes on for minute, and then goes to standby
This could be anything but is more than likely a problem in the power supply or control board. There really are not any user serviceable parts in these units and they have dangerous voltages. Repair is best left to a professional.
Jun 15, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Sylvania SRPD442 42 in. EDTV-Ready Plasma Television Logo
153 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
