Question about PfaFF Sewing Machines
Lost screw from Pfaff 18.8 bobbin case
What screw can replace my lost screw in the Pfaff 18.8 bobbin case
  • PfaFF Master
  • 7,365 Answers
Check with these sites and ask or email them
sewvacdoctor.com
a1sewingmachines.com
Posted on Nov 08, 2012
sweetymommy
  • 4 Answers
SOURCE: Pfaff Creative 1371
Did the machine get dropped, or otherwise roughly handled? Or have a rough, bumpy ride back home, etc? That could explain why it's not working correctly.
Posted on Aug 06, 2007
ahamed100
  • 148 Answers
SOURCE: Bobbin case.......
A bobbin case for accommodating a bobbin which has a shaft portion and a collar portion formed on both sides of the shaft portion on which a thread is wound, the bobbin case comprises: an opening being opened on at least one side of an axial direction of the shaft portion, for detachably accommodating the bobbin; a thread take-up portion provided in the axial direction opposite to the opening, for pulling out the thread of the bobbin; and a holding member which makes contact with the bobbin and nonrotatably holds the bobbin.
Posted on Mar 04, 2008
geemarie
  • 876 Answers
SOURCE: I'm trying to do shirring?
My machines has a shirring foot, so I don;t have the same machine. However, I do not think that elastic thread will work in the bobbin. Have you tried it the other way around? Do you have your manual?
Posted on Aug 07, 2008
  • 97 Answers
SOURCE: thread or bobbin tension
Thread tension. Beware of adjusting the bobbin screw. Pfaffs maintain their tensions just fine without adjusting the bobbin tension, unless you're using some crazy thick or fine thread. If you must change your bobbin tension, you would be well-advised to buy an extra bobbin case, because re-calibrating your tensions after changing them can be less than fun.
Increase your top tension, and your looping should cease. I normally keep my tension around 4.5. Also make sure you're using a good quality thread, and that there's nothing in the upper tension assemblies. Sometimes a tiny piece of debris can keep the top tension from applying enough tension, so turning the machine off and blowing some canned air in there can help as well.
Good luck,
-R
Posted on Mar 11, 2009
  • 6 Answers
SOURCE: Pfaff 2040 Tiptronics bobbin case rotating out of position
Sounds like you need to put a drop of clear sewing machine oil in the raceway of the hook. Then sew on some scrap material to soak up the excess oil.
Posted on Mar 12, 2009
Pfaff quilting machine bobbin stuck
Is there is a wad of thread that is holding the bobbin captive? If so, you'll need to use small scissors and tweezers to snip away and pull out the threads. Patience!
If the bobbin is actually stuck in the bobbin case, it could be because it is the incorrect bobbin for the machine or the bobbin was over-filled with thread. You may just need to use force to remove the bobbin. It may damage the bobbin and, possibly, the bobbin case. They are both replaceable. Or you can pick up an additional bobbin case and bobbin and try the new ones in your machine.
Mar 10, 2017 | PfaFF Sewing Machines
What size bobbin for a pfaff creative sensation
Bobbins (10pk), Pfaff #820921096: Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts > Creative 2.0
  1. Cached
  2. Similar
Product Details. Guaranteed to fit Pfaff Sewing Machine Models: Group J: creative sensation, creative sensation pro, creative performance, creative vision, ...
Pfaff - creative sensation™ pro
www.pfaff.com/en-US/Machines/creative-sensation-pro
  1. Cached
Now your PFAFF® creative sensation™ pro can embroider faster than ever ... needed to achieve perfect balance between the needle and bobbin threads.
Pfaff - Accessories
www.pfaff.com/en-US/Accessories?page=5
  1. Cached
Results 161 - 200 - Revel in a wide range of PFAFF® accessories .... blue bobbins for sewing, embroidering or experimenting with the creativeBobbin Case. bobbin for pfaff creative sensation Google Search
Dec 31, 2016 | PfaFF Sewing Machines
Thread caught behind the bobbin case holder
Take off the presser foot
take off the needle plate
take off the bobbin plate
take out the needle,
clip bobbin free,
Examine the bobbin carrier on how it fits into place. (important)
Lift out the bobbin carrier.
Each machine is a little different. You may want to take pictures as you do each step for later reference. Use something like an old egg carton or a muffin tin to keep your parts from rolling around or getting knocked off an lost.
Have fun.
Nov 05, 2012 | Pfaff Creative 4.0 Sewing Machnie
How do i fix the tension on my pfaff tiptronic 2020
It sounds like you need to adjust the bobbin tension. There is a small screw on the bobbin case to tighten/loosen the thread's tension coming out of the case. Refer to the user manual on the procedure to set it.
Nov 28, 2011 | PfaFF Tiptronic 2040
Bobbin trouble
Remove the needle plate for better access and try using a seam ripper to gently cut the threads and continue to remove with the tweezers.
The needle plate is the metal plate under the presser foot and is held into place with at least two screws.
The bobbin fits into the bobbin case.
The bobbin case fits into the bobbin shuttle.
Once you get the jam cleaned away, raise the needle to it's highest position and remove the bobbin case and/or replace the bobbin case.
Jamming can cause the machine to be out of time.
If you thead the machine with the presser foot up, have the bobbin inserted into the bobbin case correctly and the stiching is loose and loopy the machine may need to go into the shop for service.
May 01, 2010 | PfaFF Hobby 4260
How to adjust lower tension on pfaff hobby 370
On the bobbin case is a screw. Mark the case with a tiny dab of nail polish and the edge of the screw. This will tell you where you began.
Turn the screw: right to tighten and left to loosen.
This is an adjustment that is usually not needed unless you are changing the weight of the thread being used on the bobbin.
Mar 12, 2010 | PfaFF Sewing Machines
I have a Pfaff Expression 2038 that has been fixed three times for the same problem. Needles keep breaking off and the bobbin mechanism is revolving freely. I just had it repaired a week ago and the...
I have a Pfaff Expression and the bobbin casing does not come out so I can clean out behind there. Usually in my other machines there are 2 little levers that turn and then you can pull the whole bobbin shuttle out
Jul 04, 2009 | PfaFF Sewing Machines
Bottom (bobbin thread) makes loops
I don't have the same brand as yours, but on my machine there is a little screw on the bobbin case that you tighten to increase the bobbin tension. If you've got one, turn it 1/8 to 1/4 turn at a time.
Jan 15, 2009 | PfaFF Hobby 4260
Sewing Machines Logo
43 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
