Question about Desa International GWP20T GLOWARM Wall Mounted Panel Heater
When i let go of the button pilot light goes out
I have a gloworm propane heater with blower and when i start it and hit the buttom for the pilot the pilot lights then when i let go to try to put it on it's setting the pilot light goes out do you think it needs a new pilot
  • 188 Answers
SOURCE: propane heater has spark but wont light
ODS/Pilot may be clogged make sure you clean it out according to the instructions in your owner's manual. If you need a copy of the manual let me know and I will try to find it for you. If it is still not working it could be the gas regulator or the ignitor cable. For Glow warm parts contact Master Parts at 800-446-1446 or you also can find them online at www.masterparts.net. I hope this helps you!
Posted on Jun 30, 2009
  • 70 Answers
SOURCE: Glo Warm propane heater started
sounds like when you blew heater out with air compressor you moved brick so flame isn't hitting bottom of brick like they should. You should try and put brick back on top of flame so that you don't get to much heat on the refractory of the heater.The refractory will take the heat for awhile then refractory will start to break down. Then you will either have to install new refractory or replace heater
Posted on Jan 18, 2009
tinytrees
  • 92 Answers
SOURCE: Glo Warm propane heater won't light
There is really not a lot to go wrong with the heater itself so my first guess would be that the regulator is bad, not letting the proper amount of gas through. You can check it for leaks with a bottlee of soapy water but even if you don't see a leak there is a rubber gasket inside with a pressure spring that is probably bad.
Posted on Feb 04, 2009
  • 70 Answers
SOURCE: I have a set of propane gas logs. The pilot light
Check the connection of the thermocouple or replace it if connections are tight.Pilot safety valve may be badreplace gas control valve.
Posted on Oct 24, 2009
SOURCE: My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Posted on Dec 04, 2009
Furnace goes out when blower should start
There is a sensor called a pressure switch that is attached to the area of the blower motor for the exhaust fan. It is bad or plugged.
Nov 16, 2015 | Heating & Cooling
I have a Intertherm mac 1155 propane gas furnace. The pilot lights, burners come on, blower comes on and in a few seconds the pilot goes out
Goes out or is blowen out ? could be a short pilot needs cleaning
Thermocouple could need replacing or the heat exchanger is split and the fan is blowing it out
Sep 14, 2012 | Heating & Cooling
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
This is a new unit - used 4 times. The gas will no longer flow and light the unit. Sometimes I can get the pilot to light but when I turn the valve to light the heater the pilot goes out and nothing. The...
Sounds like the thermocouple is not working or you are not keeping the start or pilot button depressed long enough before turning gas valve to on position. Check to see if thermocouple end hasn't come loose, the pilot should be hitting it. This produces the small electrical current necessary to open gas valve. Hope this helps.
Oct 02, 2010 | Stainless Garden Sun Steel Propane Patio...
Pilot light will stay lit but when heater comes on, the pilot light goes out - propane
Is the pilot flame hitting the thermocouple with at least 3/4 of an inch of surface on it? Then if it is then need to replace the thermocouple about a 5 dollar part. let me know if you need anymore help ken
Jan 31, 2010 | Procom Heating & Cooling
Pilot light will light but when i release the pilot button it goes out
You will need to change the thermocouple. It is the copper probe that goes from gas valve to flame. Any good farm store should have one.
Jan 11, 2010 | Reddy Heater RLP100 Portable Forced Air...
The heater will not stay lit.
i have to start my heater manually. whats bi start it the controller works its when the heater hits its tempature it will turn off thats good, but when i re-start it with the control it wont start. i have to do it manually remove the cover on the heater and push a buttom on top. the pilot is always on?
Jan 31, 2009 | Williams 1403622 Gas Compact Heater
Kozy world propane wall heater. The pilot light will work
Sounds like you have a common problem with infrared heaters. They are very dust sensitive and they will light and then go out when they are dusty. If you have already tried to blow it out at home you need to take the heater to your propane dealer who will take the heater apart and blow it out correctly. They will then hook it up to their gas line and make sure that the problem is fixed. I hope that you haven't blown up into the bottom of the heater where the gas line is connected. There is a diaphragm up in there and if you blow into it you risk messing it up to where it won't work at all.
Nov 15, 2008 | The Companion Group Kozy World Portable...
Desa International GWP20T GLOWARM  Wall Mounted Panel Heater Logo
35 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
mcijoe
Level 1 Expert
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
