Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Would throwing the circuit breaker help? IS there another way to reset?
  • Official Brand Answer
  • 4,342 Answers
Hello - Try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a communication issue with the control panel or wiring failure which would need further diagnosing.
Posted on Nov 07, 2012
5 Suggested Answers
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
kakee
  • 1268 Answers
SOURCE: Same problem. Dishwasher won't start and wash light blinks.
If the wash light is blinking, there's an internal component problem there. Mainly the fuse is blown if it's blinking. Try to unplug the power of the unit overnight to reset it. If the same problem occurs, better have it repaired. If you can manually check the back panel of your machine to see if there's an open or shorted wire there, resoldering them could possibly fix it. The last resort is to contact a repairman to replace the burned internal electronic component.
Posted on Jun 30, 2009
SOURCE: Frigidare fdb1500lfco wont start. Heat dry light
Press and hold the heat dry button and it will turn off, so dishwasher is usable again.
Posted on Jun 01, 2010
markfreedman
  • 312 Answers
SOURCE: when you hit start the
Hi, There are several possiblities of what is happening. Since I am not there in person I will go through the steps I would ordinarily do to determine what was happening. Here is the sequence:
If the dishwasher is set up for the heavy duty, "sani-cycle" type of cycle. Then it may take quite a bit of time to start running. The reason being is that the heater in the water tank is heating up the water to above 140 degrees.
To test this, cancel the existing cycle and start again shutting off all forms of pre heating, etc.and see what then happens.
The other option would be that the timer motor (not the cancel cycle part) has failed. Since the machine appears to be new, I would get it repaired under warranty from Frigidaire if this applies.
Hope this helps,
Best Regards,
Mark
Posted on Feb 16, 2011
95 4 runner power window fuse location
There is a 30amp circuit breaker. They reset automatically after a while. When the motors start to go bad, they don't raise the windows fast, and they can throw the circuit breaker. Figure out which motors are struggling and replace them.
Aug 14, 2017 | 1995 Toyota 4Runner
Table saw will run a couple seconds and the thermal reset breaker throws - no problem w/ incoming voltage, I guess it needs replacing?
SOUNDS like if a breaker is thrown,it is possible that you are overloading that branch circuit(meaning there are other working outlets on that circuit) SOUNDS like breaker is working fine.
Mar 13, 2015 | Saws
If there is no power for either the washer or dryer, is there an internal fuse or reset button
I assume you checked the circuit breaker for this outlet? Both appliances are plugged into the same outlet? I would try unplugging both appliances then attempt to reset the breaker again....throw it completely to the OFF position, wait 10 seconds and throw it to the ON position. At this point we are assuming the breaker is working. It could actually be defective. It could be tested with a meter or test light. If you don't have that try plugging a lamp or another device into the outlet the appliances where plugged into. If it works you know your breaker, wiring, and outlet work. If not you need to troubleshoot that...perhaps a ground fault breaker somewhere in between? If the outlet works with the test lamp, next plug in one appliance at a time to try to determine which pops your breaker.
Feb 06, 2015 | Dryers
I have a GE Triton Eterna EDW30000G Series and the lock button will not shut off, how do i reset it?
Likely it is stuck Mid-Cycle. Try disconnecting power to it by throwing it's circuit breaker off for 20 minutes or so.
Dec 29, 2014 | GE Dishwashers
How do you reset the control panel on an a mana oven model number AOES3030E
The easiest way would be to throw your circuit breaker, wait 10-15 minutes for good measure, to clear capacitance, then flip the breaker back on. If the display is damaged or dim, get the display board re-built.
Sep 30, 2014 | Amana Ovens
Cuisinart juice sqeezer throws circuit breaker
Is this a new juicer, have you used this before without the circuit failure?
Most circuits in the house will be are 15 amp breakers. If the appliance has a high amp load then this can cause it to switch the breaker turning on or off.(due to to voltage spikes) I have a waffle iron that does the same thing if my refrigerator cycles while the iron is on.
There are a few things that could cause this. But before anything else I would try the juicer in a different plug that is on a different circuit, like the living room for example. If that works well then I would start looking at you may need to replace the circuit breaker, they do go bad.
Apr 05, 2012 | Cuisinart Juicers
Power is connected but dishwasher will not start
Make sure (with and electric field tester/2-prong tester/DMM/VOM) that there's 120VAC to your
dishwasher. You can also check the circuit breaker - it may be OFF or TRIPPED.
Its easy to see when a breaker is OFF, but harder to see a TRIPPED breaker - the toggle
stops halfway between ON and OFF when a breaker trips, and its easy to miss in the dim
light of a typical garage or basement (this electrician knows from experience). To reset
a TRIPPED breaker, you must throw the toggle
switch to OFF, then reset it by throwing the toggle to ON.
If your residence has a fuse panel, check you fuse and consider buying a reset-able screw-in
replacement from your local electrical supply.
Feb 20, 2011 | KitchenAid Dishwashers
My head lights will turn off after a short time on. If I cycle the headlight switch it solves the problem for anywhere from a few seconds to 15 or 20 minutes. This only involves the headlights, not the...
Headlights are usually protected by self resetting circuit breaker instead of a throw away fuse. If you are certain of no dead short in the headlight circuit, the only other option is a new circuit breaker. Since you get various times of normal operation after the breaker resetts, I would suspect the breaker rather than a short.
Jan 22, 2011 | Ford Explorer Cars & Trucks
Drayer working but no heat
No heat may mean that one side of the 240 volt circuit breaker is tripped or one fuse of the 240v circuit at the fuse/breaker box is tripped. Just replace/reset the fuse or breaker which ever you have.
Dryers will have controls working but not heat if it happens to be that particular side of the 240v circuit that tripped or fuse burned.
Jan 30, 2008 | Dryers
Breaker keeps throwing
jhweis80 Why do you think the problem is the dryer? The circuit breaker itself could be bad and this is what I will check first. Probably you need a professional electrician to do it for you. Gendos post back...
Jun 27, 2007 | Maytag Neptune MDE6700A Electric Dryer
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
146 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
