Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid superbra 24 oven
How do i use the selfcleaning partof older 13yrs kitchenaid superbra 24 oven
  • 198 Answers
Select clean on the control panel and set stop time then push start
Posted on Jan 05, 2009
Kitchenaid Superbra double wall oven still not heating. Replaced thermal fuse of top oven; lower is OK. Also replaced the 2nd thermal fuse near the control panel on the top of the unit. Any ideas?
Get me a complete model # number for this oven We then can give you step by step what to check .Knowing how to use a meter Is a big help with any electrical issues . Getting Us the model will tell us what is used to control your appliance, The big and first thing to check is the power do you have it all were it needs to be most ovens run on two legs of 110/120 volt. in combo Make 220 volt It all needs to be there or you will not get proper heat
.https://www.youtube.com/watch?v=NOdYp8CFjdU&feature=share
Feb 02, 2017 | KitchenAid Ovens
Will not turn on after using selfclean
Hey there, does it not turn on immediately after you use self clean? Or will it work once oven has cooled down? Due to very high temperature during self clean, oven may need to return to a safe temperature before next operation...
May 22, 2011 | KitchenAid Architect Series KBHC109JSS...
I have a kitchenaid gas range and the door is stuck in lock
hold the oven door lite switch closed and put it on selfclean it should activate the door lock
Nov 14, 2009 | KitchenAid KGRS807S Gas Kitchen Range
Kitchenaid superba oven stovetop oven door will not open after se
When the oven goes into clean mode the door is automatically locked as a safety feature. I would put it back into clean mode again, let it clean for a while and then hopefully when it cools down the door will open. good luck .
Mar 20, 2009 | Ovens
Kitchen aid, self cleaning
The only solution is to get a new oven, The paint in the oven burned off, and now the electic board is burning out. This oven when it hits about 400 degrees it makes this chemical plastic smell, and at selfcleaning it makes the same smell for 3 1/2 hours, and come to find out it burned the paint off
Jan 04, 2009 | KitchenAid Architect Series KEBC107KSS...
My kitchenaid oven will not open after selfcleaning it
unplug the stove, and plug it back. or you can set the oven for self cleaning and when is done the latch will replace.
Dec 07, 2008 | KitchenAid KESC307 Electric Kitchen Range
Frigidaire electri clean selfcleaning feature
It locks automatically. You can download the manual from Frigidaire here (as I just discovered while trying to figure out how to use the self-cleaning feature :) ): http://www.frigidaire.com/support/manuals.asp?NewSearch=New+Search
You don't need to type in the whole model number. For example, if the model number (found in the upper left when you open the oven door) is RSE37BAW*4, you only need to enter RSE37BA.
Apr 27, 2008 | Frigidaire Ovens
KitchenAid superbra range KGST307
I am not a repair man or anything, just an owner with the same gas range slidein appliance. What we have found to work was 1) plug in the probe into the socket in the oven 2) Turn on oven with the probe set at the minimum 160 degrees. and oven temperature to 325 degrees. 3) click start 4) wait for oven to reach probe temperature. 5) oven will then beep show end 6) Click cancel 7) open door and remove probe. 8) wait five minutes before trying to use again. I hope this helps you it has work for us so far. 6)
Aug 27, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
123 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
