I have a dell vostro 1700 laptop with dvd cd rewriter ,it keeps ejecting the disc , the disc runs fo a minute or so then ejects itself , how can i get it to find the information on the DVD
I have a dell vostro 1700 laptop with dvd cd re-writer ,it keeps ejecting the disc , the disc runs for a minute or so then ejects itself , how can i get it to find the information on the DVD
  • 416 Answers
Replace drivers if not solved then replace drive
Posted on Nov 15, 2012
5 Suggested Answers
  • 356 Answers
SOURCE: dvd will not eject from slot drive of dell vostro 1510
Restart your computer and enter set up bios. Try ejecting your dvd rom from there... it that doesn't work, get a pin and insert it in the pinhole on the dvdrom whuile pressing the eject button... that should do the trick!
Posted on Jun 03, 2010
krihard
  • 407 Answers
SOURCE: cd/dvd drive ejected every 5 minuts
hi tray problem replace it ............
Posted on Dec 28, 2008
  • 62 Answers
SOURCE: Dell Studio 1700 - dvd/cd will not work
Hello
i have the same laptop and you have to install it properly because vista needs time
Thanks
Posted on May 24, 2009
SOURCE: Dell studio 1537 - The cd/dvd drive makes stranges
Dell studio 1537 making grinding noice during burning process.and burning will not complete.
Posted on Oct 25, 2010
Del vostro 2510 dvd drive won't work
Try restrting your pc
Try redownloading dvd drivers from dell website
Mar 15, 2013 | Dell Vostro 2510 Laptop
I have a dell vostro 1510 and can't get my cd out. When I click on the eject button, it lights up, but nothing happens.
What you might try is going to "My Computer" or "Computer", right clicking on the CD drive, and clicking "Eject". If that doesn't work, go find yourself a fairly small paper clip, stretch it out, and use it to poke that little hole on the disc drive itself that is a manual eject device.
Aug 23, 2011 | Computers & Internet
I insert a CD into my CD Drive,the Drive can not read it and I can not eject it. CD Drive motor always tries to read CD. How must I do to eject the CD
you can manually eject the dics with a straightened paper clip via a small hole on the face of the drive it will help you retrieve the disc
Jan 26, 2011 | Dell Vostro 1510 Laptop
Won' read discs, won't eject manually or through Eject under DVD drives.
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 14, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
My PC won't allow me to right click to choose the eject option for a CD. I want to know if there is a way to remove the CD manually.
The DVD drive itself has a small horizontal 'eject' button that you can press to eject the disc.
If the button fails the disc is stuck however the DVD drive will have a small hole near the eject button- about 2mm in diameter. Straighten a paperclip or similar and push into the hole until the disc drive mechanism releases and opens.
Thanks,
Javaftper
Aug 07, 2010 | Dell XPS M1330 Notebook
I have cd that won't eject. it is a "green" cd and is thinner that standard cd-roms. I have a Dell Vostro 1510 and am using Windows Vista premium.
There is usually a little hole in the dvd draw facia that you can push a thin object like a paper clip into. this manually opens the draw
Jul 10, 2010 | Dell Vostro 1510 Laptop
I have a Dell Studio 1737 and the DVD is stuck and the computer will not respond! What can I do?
there should be a very small hole on the dvd panel its used for when the unit stops ejecting cd/dvd find the hole and stick a long pin into it as you push the pin in the tray will open
Jun 19, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
Dvd will not eject from slot drive of dell vostro 1510
May 24, 2010 | Dell Vostro 1510 Laptop
I can't put dvd disk into Dell Vostro 1310
1. Switch off the laptop
2. Press the power button to switch it on.
3. Instantly after pressing the power button, start pressing " F2 " key on the keyboard to enter the BIOS setting.
4. Now press/touch the " eject button " of the DVD drive and now you are done, you will get the disc out.
I stole this from http://www.tech-tweak.net/2009/11/how-to-eject-stuk-dvd-from-slot-load.html
Mar 17, 2010 | Dell Vostro 1310 Laptop Computer PC...
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
