Question about Fender Rumble 100 Bass Guitar Amplifier
Broken input the input jack is broken
    New Friend:
  • 14 Answers
Replace. hopefully its a simple plug and play so you just have to plug in the new input.
Posted on Nov 24, 2012
Why is there almost no signal In mic input?
electronics can be effected by oxidation of the contacts the input jack the volume and tone control pots must be cleaned and lubricated try a cleaner from radio shack this may help if not input jack may be severely worn or the microphone may be in need of repairs to it's plug or cord there could be a shredded or broken wire connection
Aug 21, 2014 | Music
Fender telecaster keeps cutting out
the input jack is either dirty=crackling sound in and out or broken or a wire has come off your input jack or is loose
May 22, 2012 | Fender American Deluxe Telecaster
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
Input jack fell inside
Yes, the jack MAY actually be broken. It will need to be serviced. Run cables through the handle to avoid plugs from being yanked sideways and breaking the jacks.
Aug 23, 2011 | Roland Cube-20x (20w 8" Modeling Guitar...
Hello. I have a Boss MT-2 distortion pedal. It will not power up with the adapter or battery. Wondering what could be wrong. Any suggestions on what to look for? Thank you!
The battery is connected via plugging in the input guitar cable ( a seperate contact is made at the jack). Sometimes this can be broken. Usually this failure is caused by someone stepping on or yanking a cable and the solder is broken at the jack/board attachment. This can be the input jack OR the power jack. Occasionally the circuit board or the traces on it are cracked, requiring jumpers to be installed on the board. In any case, open the pedal and look for these problems.
Aug 15, 2011 | Boss Mt 2 Metal Zone Effects Pedal
Hi :) I have a problem with my Boss mt-2 pedal. Whenever I insert the jack plug in the input, the adapter switches off automatically. The pedal works fine with battery and no problem is created. This only...
Make sure you are NOT using a TRS (stereo or three conductor cable) type cable. PLugging into the input should turn the pedal ON, not off. The switch on the jack may be broken or soldering to the circuit board may be broken OR worst case, there is a crack in the circuit board.
Mar 16, 2011 | Boss Mt 2 Metal Zone Effects Pedal
I just bought a used valveking 100 half stack and the 1st channel does not work, second channel works but seems to have a loose input jack as connection is intermittent and affected by wiggling the input...
Same thing... they probably broke both jacks. Sometimes the guts of the jack is broken and it doesn't appear to be broken but is broken internally. You may find broken solder on the pins to these jacks as well.
Note that the two input jacks have a different gain.
Here is schematic: http://elektrotanya.com/peavey_valveking_100_212.pdf/download.html
Dec 02, 2010 | Peavey Valveking Head
Hi. I've had this transistor Marshall head for about a year now but lately whenever I plug a patch cord in the input jack and turn the amp on, I get crazy amount of distortion. I know this only a problem...
A educated guess points to either broken soldering or a broken ground on the input jack itself. This is a CHRONIC problem of amps because people trip over the cord and it yanks the cable and jack sideways breaking it or the solder where it attaches to the circuitry.
To avoid the problem, loop your cable through the handle of the amp so when cable is yanked it doesn't yank the jack so hard.
Nov 16, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
The sound on my mg100hdfx cuts out sometimes then its fine what could this be
Common problems are broken or intermittent input jacks or cracked circuit board or soldering or broken volume controls. Another one is a bad switch contact on the jack for PA input connection. All these are internal and require servicing.
External problems are guitar and cable problems.
Jul 15, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Input wires broken loose, not sure where the go to
The center pin is your tip..which should have a wire going from 1/4" jack to the XLR jack. Pin 1 is earth ground...should be coming from 1/4" jack sleeve. Pin 3 would come from the 1/4" jack ring.
http://upload.wikimedia.org/wikipedia/commons/thumb/8/81/XLR_pinouts.svg/540px-XLR_pinouts.svg.png
If you are still having trouble, post links to pictures of the internals of the guitar showing the assembly.
Mar 27, 2009 | Music
Fender Rumble 100 Bass Guitar Amplifier Logo
205 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
