Question about Samsung Stainless Steel Over The Range Microwave Oven Smh1611s
My samsung over the rang microwave stop working has power to outlet no power to unit
    Top Expert:
  • Samsung Master
  • 9,472 Answers
You will need to check the fuse to see if it has blown. If the fuse is good, you will need to replace the control board. Here is the board to order.
Posted on Nov 08, 2012
Why won't Samsung OTR microwave work?
thanks a lot for informative reply everyone! worked well for me, sharing it with http://dissertationwritingservices.org/ now!
May 17, 2017 | Samsung Microwave Ovens
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
How to replace fuse on the samsung SMH1816s over the range microwave
no problem with fuse - it is due to lose contact on the panel board - open from the front , most probably their will be lugs which may had come out /lose. .
Jan 10, 2014 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
Replacing fuse in samsung microwave model number shm9187
there should be a fuse inside on the AC line and it may be on the inverter(power) board of the unit.
Nov 02, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
Over range microwave model jvm1650wb008 fan works nothing else does
Check to see if circuit breaker is tripped in the electrical panel, or if it is connected to a ground fault outlet, it may have tripped. Sometimes there is one ground fault outlet serving others in series in the kitchen.
Nov 25, 2011 | GE Microwave Ovens
Samsung Microwave model # SMH7178STD just stopped working.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find Samsung-specific parts here: http://www.samsungparts.com/search/search.asp
Nov 04, 2007 | Samsung SMH7178STD Microwave Oven
MAYTAG mmv4205aab OVER THE RANGE MICROWAVE
It could easily be a bad line fuse and/or line filter. To access you will need to unplug the unit and remove the outside case. Inside the unit, where the A/C power cord comes in, there should be a small circuit card (part #237068) located somewhere with a fuse mounted on it. This is your input line filter board with line fuse. Replace the fuse, first and see if this fixes your problem. This is a 20amp appliance fuse that you can purchase at any hardware store. Make sure you place the cover back on the unit BEFORE you plug it in. It is not safe to have this area of the microwave exposed with power applied. High potentials in the 4,000 volt range are present! If the fuse does not correct your problem, the circuit card runs about $26.00. Good luck and hope this fixes your problem.
Aug 04, 2007 | Maytag MMV1153A Microwave Oven
Samsung Stainless Steel Over The Range Microwave Oven Smh1611s Logo
63 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
