Question about Archos Gmini 402 Digital Media Player
Gmini 402 camcorder freeze/format
It froze up, so after the battery died, i started it up, it said "Read Access Error" I then click format and asks me if i wanna do it from the computer or if i just format it on its on. No matter what I do, it doesnt format. When its plugged into the computer, it doesnt recognize it as a GMINI 402 or ARCHOS DEVICE, it says removeable storage and in properties says that there is no memory availabe on the hard drive, it doesnt even recognize the hard drive. when i try to add the updated firmware, it says that it must be formatted but it wont let me. I really need to fix this problem, i do everything w/ this camcorder and i dont have an extra couple of hundred dollars sitting around. So if anyone has any suggestions on how to fix this, please let me know, you dont even know how much I would appreciate it. Thank You.
Well.. I had the same problem and did a lot of "trial and error' techniquies. I tried to format using the DOS utility which didnt work. So I waited until windows recognised it as a storage device (not Archos Gmini) and tried copying some files from the PC to Gmini (which will not get copied over). Then disconnect and switch off the Archos Gmini. Now power on the Archos Gmini and it will start off on Arclibray updates and the system will start off normally and home screen appears. Now get into Archos GMini setup and format it. Format will be successful and the next time you start up gmini, it will work fine. Lemme know if the solution worked for you.
-A Friend!!!
Posted on Sep 11, 2008
I have the same problem and i treid that and it comes up with cannot direct access file or suthing like that
anymore help please?
Posted on Feb 25, 2008
  • 691 Answers
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
Posted on Jul 26, 2007
3 Suggested Answers
SOURCE: archos gmini 402 camcorder
Try turning the unit on with the hard drive disconnected. When I did this (mine had a similar problem) a screen came up and asked me if I wanted to format. I plugged the hard drive back in and reformatted. I had to format twice, but after that it worked fine.
Posted on Jun 25, 2008
SOURCE: I need a replacement screen for my Archos 402 Gmini
Broke the Back on my Archos Gmini 402 20GB and if anyone has one for sale broken i am willing to buy it from them for the parts as all i need is the rear panel and the screws for the Rear panel.
Posted on Jun 16, 2009
Archos Gmini 402 Camcorder will not charge properly.
i think it has battery problem. its not charge properly. check its cable or other wise change the battery with new one
Jan 19, 2012 | Archos Audio Players & Recorders
Jan 26, 2009 | Archos Gmini 402 Digital Media Player
Gmini hard disk reading problems
My Gmini XS202s did this twice both time cause the battery went flat while moving files across (I should always charge device while connecting to PC)
First time I reformatted device as FAT32 using fdisk (Windows formatting tool should do same)
Then downloaded latest AOS and copied to root directory. [get AOS from http://www.archos.com/support/support_tech/updates.html?country=gb&lang=en]
second time I ran mkdosfs /media/disk (disk was mount point for gmini). This seemed to fix the device and I lost about 20 files. but better than reformat.
Dec 17, 2008 | Archos Gmini XS202 MP3 Player
Archos gmini 402 camcorder
May 04, 2008 | Archos Gmini 402 Digital Media Player
Archos Gmini 402 camcorder 20GB digtal media player
Hi there this may seem a silly question but the ear phones you are using are a stereo ear phone? or the adaptor to your archos is a stereo one?
Apr 09, 2008 | Archos Gmini 402 Digital Media Player
Freezes on start up
If you have problems with the file system on your Gmini? 402 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini? 402. ? Quit all running applications. ? Properly connect the Gmini? 402 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini? 402. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini? 402 from your computer. Try it now and see if makes any difference,
May 22, 2007 | Archos Gmini 402 Digital Media Player
DEVICE HAS'' READ ACCESS ERROR-CANNOT READ FROM HARD DISK''
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. If not you could try formatting it using a DOS prompt.
May 22, 2007 | Archos Gmini XS 100 MP3 Player
Klackitey Klack
If the drive is ticking, it suggests the actual HDD is dying. You can try the following to see if you can fix any disc errors through your PC, however if your PC does not recognise a drive has been attached you may be unable to do anything other than have it repaired elsewhere. If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
Apr 04, 2007 | Archos Gmini XS 100 MP3 Player
Archos Gmini 402 Digital Media Player Logo
1,252 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
