Question about Ovens
My samsung PKG100 electric single oven has no power at all eventhough 230volts are throughout it
2 Suggested Answers
johnrodgers1
  • 73 Answers
SOURCE: How to light a Wolf Gas Oven, model PW362718,
you cant !!! need power to operate if it has a glow coil ignition
Posted on Feb 06, 2010
An F10 error just appeared on my Kenmore Oven. What is that?
The F10 error code indicates a runaway temperature condition. If your oven is overheating, unplug the power cord for a few minutes. When plugged back in if the oven is still overheating, you will need to have the temp sensor & control checked.
Feb 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
The oven won't come on. It is a whirlpool electric single oven range
If the oven is getting power it's probably one or more of the thermal fuses. There is a thermal fuse in the wiring harness that feeds the control board. Accessible from the front. The other fuses are chassis mounted on the back or top.
Jun 26, 2010 | Whirlpool GBS307PR Electric Single Oven
Oven does not heat up.
You will probably find that it is the oven element that has failed.
This is to be found at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 01, 2010 | Baumatic B187 Stainless Steel Electric...
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Dec 09, 2009 | Maytag 24" Built-In Single Electric Wall...
Oven will not start it is a samsung BF641FST built in oven
How old is your oven? If it's within it's two year warranty samsung will send an engineer out to fix it no charge
May 03, 2009 | Viking VESO176 Stainless Steel Electric...
Bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Jan 13, 2009 | Bosch HBL 442 / HBL 446 Electric Single...
GE JT930 Electric Single Oven Problem not working
power controller board inside control panel upper right side, normally gets trashed with power surge from utility company power issues
Oct 07, 2008 | GE JT930 Electric Single Oven
Ge jkso5 single oven
Turn power (pull out the plug) for 5 minutes and reinsert. If this doesn't fix it, you'll need a new circuit board. New and rebuilt boards are available from various vendors.
Mar 09, 2008 | GE JKS05 Electric Single Oven
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
