Question about Craftsman Garden
Craftsman Model 917.273821, starts, runs but at times it squeeks when in forward and have to put in neutral then forward
Recently I changed the mower deck belt and thought it would solve it but it didnt. The problem happens when Im moving forward, it sqeeks /grinds so then I put it in neutral or go reverse then forward. this started to happen in last month and bought a drive belt but has not replaced it yet. does anyone know how to fix this? I plan on using tractor during winter season.
  • Akil Amin Nov 06, 2012
    I have already check the pin in the back by hitch and it is pushed in and I can ride it but sometimes it grinds when going forward.
  • 79 Answers
SOURCE: Craftsman DGS 6500 garden tractor won't engage
Hi
There is a pin in the back by the hitch - make sure it is pushed in. If it is pushed in then check to see if there are any oil leaks under it.
Posted on Apr 10, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman LT 1000 won't go into reverse or forward
the hydrostat rearend or the belts to loose
Posted on Jun 07, 2009
mickey813
  • 472 Answers
SOURCE: my craftsman lawn tractor has a 42 in. deck, w/21
YOUR TRANS IS BAD
Posted on Oct 02, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
SOURCE: I have a craftsman lawnmower lt 2000 42 deck which
Where is the battery located on the LT2000 42"
Posted on Apr 12, 2010
Why does speed control lever return to neutral when going forward ?
this model uses a series of groves cut into mower body to maintain the transmission gear/direction , it's held into groves by a spring just under the cover , if this is broken a replacement can be gotten from sears (part# 164X39) to replace it , it should take at least five pounds of force to move shift lever out of grove to next gear , if not then your shift spring is loose or broken
Jun 05, 2014 | Craftsman Garden
Craftsman LT2000 Automatic wont move forward or backward
when you took off the bag did you pull the lever that allows you to push it around the one that puts the hydro drive in neutral its on the back a couple inches away from the eyelet you can tow with it should be released forward
Mar 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have the Craftsman 20.5 Model 944.609800 42 in mower I can get it to run but when i put it in gear or take my foot off the brake it stalls it also stalls when i engage the mower blades can you help i...
I agree it is the seat switch. This switch will let you start the mower as long as it is in neutral, the brake is set and the mower blades are not engaged. I think it is just two wires, maybe you can jump them together and see if it runs.
Gary
Aug 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When i put mower in reverse it moves very slow an when in neutral mower still moves forward have to pull lever back beyond neutral position to find neutral is there an adjustment on transmission
yes
there is a adjustment under the r/h rear gaurd just under where the lever goes to hydro unit you should see a slot and a adjustment bolt arrangement
make sure you put the tractor in true nuetral 1st then undo the bolt that clamps lever to shift arm / shaft ( this connects to plate that operates swash plate on the pump ) and move the lever either fwd or back until (without moving transmission from true nuetral ) it fits into the nuetral slot correctly and tighten the adjustment bolt - test and adjust as nescesary
here is website for parts
http://www.outdoordistributors.com/Craftsman/Craftsman_Search.html
get model and type numbers off machine ie 917-??????
here is web site for parts
Aug 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motor running will not go forward or reverse.
The transmission may be bad or the belt is slipping.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman Garden
My craftsman lawn tractor 42" cut (2007 model) cuts off when i try to engage the cutting blades
You have a safety switch somewhere that is open, like the seat, you have to be in the seat or it will kill the engine, sometimes the clutch has to be in, not moving, sometimes the gear selector in neutral, You have a bunch of safety switches that prevent the mower from spinning if you are not in your seat, not ready, etc. Check them out. Hope this helps.
Apr 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lt1000 rider 42 in deck is stuck in gear and wont go into neutral. so i cant get it started.
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42" 19.5hp B&S Stalling
i have a crafsman mower and it only cranks it wont start wat would be wrong
Jan 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
29 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
