D-Link dwl2700ap always restarting..need help
We got this d-link2700ap..the first few years it work just find but recentlyit keeps on restarting...whats wrong...? need help all experts around the world...please...
    Sergeant:
  • 366 Answers
Check Firmware version here
Check if any source of interferences came around AP
Check if environment changed (water in, broken shell, connectors integrity.....)
Use AP manager software to check logs file and find possible reasons for restarting.
Posted on Jan 06, 2009
Hoover 500m top loader washing machine fails to stop at 'OFF'
timer and dont think u can get them any more
Jan 18, 2013 | Washing Machines
Computer restarted during restore while trying to install windows 7 now wont work. An error pops up saying...... The computer restarted unexpecttedly or encountered an unexpected error. To install windows...
hi Mike.
this is all i could find.
Try the following...
1. Power off the laptop.
2. Power on the laptop.
3. As soon as you see the rotating loading circle, press and hold the Power Button until the computer shuts off.
4. Repeat this process a few times until you see the "Preparing Automatic Repair" screen.
5. Now you want to let the laptop boot to the "Automatic Repair" screen.
6. Click "Advanced Options" and then select "Troubleshoot".
7. Here you want to select "Refresh your PC", if you do not wish to erase data, or "Reset your PC" to erase all data and restore your system.
8. From here just follow the screen instructions until the recovery is completed.
NOTE: You will need to get into the "Advanced Options" in order to get the "Refresh Option". This choice will keep your data, but any programs installed will be lost.
Do not do a "Reset" as that will wipe all data you have on the laptop.
or go to this link and read up in the forum might help.
My laptop keeps restarting and installing windows how do fix this
if that does not help you go to this link.
Toshiba Satellite L655 S5096 Notebook Computer restarted during restore...
Nov 22, 2017 | Toshiba Satellite L655-S5096 Notebook
Shuts off...restarts, then runs for a few mins
If the modem is 10 years old then its time to replace it even if it was working fine if not very good to be abreast with the latest technology. The ISP must have tested the lines which must be fine because they keep on upgrading so you need to replace the modem to a latest model.
Jun 19, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
2000 Yukon driving on highway at normal spped and
It sounds like your fuel filter has got to the end of it's life and needs to be replaced. Once the fuel filter get's to dirty, the fuel pump can no longer keep the proper fuel pressure to the fuel injectors to have them work properly. The fuel filter should be replaced once a year or 30,000 miles to ensure that it's always clean. A dirty fuel filter will make the fuel pump work harder and shorten it's life time causing a costly fuel sending unit replacement. Good luck and be safe.
Jul 27, 2009 | 2000 GMC Yukon
My Hanns-G HC194D LCD Monitor Takes Forever to come on
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 16, 2009 | Samsung SyncMaster 203B LCD Monitor
My M45/S331 doesn't start nomally
its happen because you left it and it was overheat pls take care your laptop work or keep in cool place while working.
Jun 10, 2009 | Toshiba Satellite M45-S331 Notebook
D-link dir-300 router always rebooting/restarting
This is the fix from d-link:
Router rebooting itself print.gif You may be experiencing trouble with a feature known as UPnP(TM). This feature allows Windows XP and Me machines to remotely open necessary ports for Internet Applications. You may try disabling UPnP (on the router AS WELL AS your computers) to see if this cures your reset woes. Log into the web-based configuration, access the Tools page, then the Misc. button. Choose the disabled button next to UPnP. Click Apply. You should no longer experience the frequent resets.Try disabling in XP first to see if that fixes issue.
To manually disable UPnP/SSDP in Windows 2000/XP/Vista:
  • Go to Start Menu-->Run...
  • Type "services.msc" and click OK
  • Find the service named "Universal Plug and Play Device Host" service
  • Click the Stop button to stop the service
  • Under Startup type, select Disabled from the pull-down menu and click OK
  • Find the service named "SSDP Discovery Service" and double-click
Dec 10, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Samsung 80 GB IDE
hi, sounds like a faulty hard drive i would suggest downloading this http://www.seagate.com/www/en-us/support/downloads/seatools/ even though the test software is for seagate it still works for all drivers.
boot from the floppy disk it creates and it will test the drive..
Happy New Year
John
Dec 28, 2007 | Samsung (MP0804H) 80 GB Hard Drive
Computers & Internet Logo
252 people viewed this question
David Payne
David Payne
