I have minolta di550 and it is showing a error code c0400 any solution plz
SOURCE: C13F5 error
There is a small IC board under a cover in the optical secsion near the scanner, open the cover and change that small board, its called IC something, If ya need further info let me know, Ill look up the part #
Posted on Feb 20, 2008
sir fixalot
  • 146 Answers
SOURCE: error c12co in minolta di550
C12CX (X is any value)
1. Run “Hard Disk Format” selected in the following sequence: Tech. Rep. Mode - Function - Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
To enter Tech Rep Mode:
1. Press the Utility key.
2. Touch Meter Count.
3. Press the following keys in this order: Stop - 0 - 0 - Stop - 0 - 1.
4. Select Tech. Rep. Mode.
Posted on Nov 11, 2008
  • 990 Answers
SOURCE: Minolta Di550 error code C-0500
Dear sir; the error code you post out,I check the manual it said "low fuser temp" my suggestion go to check the fuser lamp inside the fuser roller of the heating unit, you may try to reset before you go for it; the easy way just open and close the lower front door,just try it and let me know the resolve. HAVE A HAPPY HOLIDAY !!!
Posted on Dec 17, 2008
  • 990 Answers
SOURCE: Minolta Di550 Copier with a malfunction code of C-OF24
Hello sir; here have few steps need to follow;
1, press "function", press "printer", "F8" press "start" machine will run about 4 minutes the start key will turn from orange to green.
2, same procedure go to F5 will run about 30 seconds.
Posted on Jan 09, 2009
goalie39
  • 469 Answers
SOURCE: Clearing a service code ''C0400'' on a Minolta CS Pro 6001
C400 is exposure lamp fails to come on, on start up the main exposure lamp should come on and do a scan.
If the lamp is not detected by the sensor, then you get the code.
Restart the machine, watch for the exposure lamp. if it does not come on before the code occurs, then the lamp or thermal fuse is likely gone.
if the lamp comes on then the code, the AE sensor is likely gone.
Hope this is of some help.
Ed
Posted on May 11, 2009
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Minolta DI450 error code C-0920
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw.
Dec 26, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta di550 error code c-13fc
Image processing board or the Print head ( What houses the LASER inside the machine they are not talking to each other so that code is displayed. Check the connections , I would go with print head 1st. Di550 is a legacy Minolta machine, might be tuff finding a print head as for Image control board WOW! Home and close front door resets if it comes back need above
Nov 19, 2013 | Minolta Office Equipment & Supplies
Of 24 error
Cof 024 - AIDC sensor contamination correction failure.The photosensore LED located under OPC drum of the AIDC sensor dirty.Clean the sensor,reset the malfunction code if the necessary perform F5 AIDC auto adjustment.
Mar 06, 2013 | Minolta Di550 B&W Laser Printer
Minolta ep4000 error code c0400
C0400 -Exposure lamp failure to turn ON
C0410 -Exposure lamp turning on at abnormal timing
Turn OFF the copier,remove the glass,Work a screwdriver trough the hole in the frame at the left front side of the copier and remove the screw that secures the scanner unit.Move the scanner to rhe right hand side of the copier.Remove 3 screws to free the scanner.(To remove the scanner turn it counterclockwise).Remove 1 screw and the wire guide,remove 1 screw and the ground wire.Unplug the exposure lamp terminal connector,unplug the thermal fuse connector.Remove the scanner from the copier.Verify the continuity of the exposure lamp and thermal fuser.If is defective change.
Jan 02, 2013 | Minolta EP4000/5000 CS/PRO Copier
My konica minolta ep1050 is displaying error code c04 can you help me how to fix it
this is not the correct error code konicsa has 4 digits is it a c0400 if so it ids the home poition sensor for the scanner clean the sensor blow it out and see if that gets rid of your error code
Jan 31, 2011 | Konica Minolta Office Equipment & Supplies
Code C0400 contact rep at certain phone #...# out of service.
c0400 is exhaust fan code. Open the front door to clear. Make also all covers are closed front and both sides.
Jul 02, 2009 | Minolta EP4000/5000 CS/PRO Copier
Hello, I'm having the Error code C0400 when attempting to use Minolta 3050. Can you help?
in minolta this error is for exposure lamp .just check ur exposure lamp.may bi it is dead or supply problem .by mian jee
Nov 21, 2008 | Office Equipment & Supplies
"to test stapler, press staple button" ... Minolta di550 with FN-105 ... HELP !!!
First make sure that you do not have the collate and staple option checked on the printer menuing system or in the print setup on one of the local machines printing to it. Ensure that when auto-staple is not used that the error stops manifesting.
Then, I would check to make sure that you are installing the correct staples, length and width for the model.
Jan 23, 2007 | Minolta Di550 B&W Laser Printer
57 people viewed this question
k24674
jasbo
jasbo
