Question about Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Sony cd-rw crx320ee driver not working
For a game i did this
Right clicked my computer- clicked on manage option in that clicked on disk management and then i tried to change the driver name ....on doing this it showed that it wont work but i didnt care of that and proceeded...after doing that iam not able to open the driver and see file in it ....what shall i do to solve this problem...
thank u...
  • 47 Answers
Power down the pc and un plug the cables attached to it then plug the cables back in and power the pc back up.. then the drive should have the built in driver recognized again thus returning use to you .. the user
Posted on Jan 09, 2009
Burner working
What operating system do you have? The drive is fully supported by XP onwards and should be auto detected. You may have to delete the current driver in device manager reboot & Windows should install a compatible driver. (Start > right-click computer > properties > Device Manager > DVD Drives > Highlight faulty drive and delete > reboot)
Also, WinXP does not allow you to burn DVDs unless you have appropriate burning software installed (e.g. Nero)
Jan 07, 2014 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Need driver
Right click on this drive in Device Manager, and allow Windows to search for the correct driver on the Internet.
Sep 20, 2013 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Dvd/cd rw sony drx-s70u-r
what sort of problems???? are you having with your sony Dvd/cd
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 11, 2011 | Sony DRX-S70U-R DVD±RW Dual Layer Burner
DEAR SIR, I HAVE AN DVD ROM OF SONY MAKE, AND WHEN I USE ANY DVD THEN ITS NOT READ THESE PROBLEMS IS BECOME FROM TWO DAYS. PLS TELL ME THE SOLUTION FOR THIS.
is any dvd the program or just wont read any dvd?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Sep 09, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My poiner dvd rw not Reinstall it show yellow mark in compute management I have a sony laptop dvd Rw dvr-k17ata please give me driver site or give hint how i solve this problem
if your computer came with a motherboard disc the sound drivers could be on it
Jun 29, 2011 | Pioneer DVR-107D DVD±RW Burner
I can't find crx320EE driver! Mine don't read any CD or DVD
make sure that the cd-rw/dvd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
Apr 26, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My Sony CRX320EE-88 cant read bootable cd/dvd. Yes it registers at the bios on boot up and its also detected on my windows start up but when it comes to playing cd's and dvd's, it cant read both of them....
make sure that the cdrw/dvd rom is getting enough power test all leads that are attached to the cd/dvd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 04, 2011 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
My sony CD-RW CRX320EE has been disabled by windows xp service pack 2
make sure that the cd-rw burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Feb 04, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My SONY CD-RW CRX320EE reads CDs but it doesnot read dvds correctly and it doest write on Cd when i want to make cd ,it makes it but the cd doesnot open. the dvds donot open but somtimes open. please help...
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 07, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My sony dvd-rom/cd-rw crx320ee not show in windows please help
Press the Open/Close button -- if nothing happens (listen closely for any sounds) and the tray does not open, it's possible that there is no electrical power reaching the Sony.
Turn the computer off.
Disconnect the power cord.
Open the side panel.
Check that the SONY is getting power, i.e., that the power-connector is fully-connected to the SONY.
Check that the "data" cable is securely connected to the motherboard and to the SONY.
If all else fails, spend $40 to buy a new CD/DVD reader/writer,
to replace your "broken" one.
Sep 26, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Sony CRX320EE CD-RW/DVD-ROM Combo Drive Logo
742 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
