Question about Lenovo G470 Core I5 4gb 500gb Hdd Laptop Blu-ray
Laptop is charging but cant turn on
First, the problem is with thingy where you plug in the charger (in the laptop) the circle thingy at the right side. so fixed it. but then after fixing it, we cant turn on the laptop. so we charged it but still we cant open it. what are we going to do now?
    Novelist:
    Champion:
  • 233 Answers
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the laptop charger is probably faulty and needs replacement.Hope this helps.
Posted on Nov 07, 2012
  • Lenovo Master
  • 7,627 Answers
When you say "you fixed the thingy" (ac jack), how did you fix said "thingy", did you open the laptop and replace the damaged/broken "thingy"? Need more info. Perhaps the "thingy" isn't fixed? Try remove any DVD,CD, USBs from the laptop, removing the "thingy" , remove the battery, Hold down the on/off button for 10 seconds, replace the battery, replace the "thingy" push the on/off button. That said, When you fixed the "thingy" was ALL power removed from the laptop AC plug, Battery, If not a short may have occurered.
Posted on Nov 06, 2012
farhangM
  • 64 Answers
SOURCE: Gateway Laptop not charging
It sounds like defective power jack. Bring it to a reapir shop.
Posted on Dec 01, 2008
  • 32 Answers
SOURCE: Dropped my gateway laptop. Now it wont charge battery.
If you do not have either a manufacturer warranty or extended warranty from the retailer use it now. Contact them. Avoid telling them that you dropped the computer...you will void a manufacturer warranty. If you don't have either option then you can continue portability with an external laptop battery. They tend to be heavy, but they tend to provide 5 or more hours of portable use. The extended battery plugs into the same socket as your regular external power supply. I have included some links for product options.
http://www.youtube.com/watch?v=q1om-j6AGNg
http://reviews.cnet.com/1990-3121_7-5127099-1.html
http://www.batterygeek.net/Portable_Power_Stations_s/38.htm
http://www.amazon.com/s/ref=nb_ss_gw_0_13?url=search-alias%3Daps&field-keywords=external+laptop+battery&sprefix=external+lapt
Good luck
Posted on Jan 19, 2009
SOURCE: I dropped my laptop and now the battery will not charge.
Most likely its the DC Power Jack. Happened to me. You can find the part online by searching for "450ROG DC Jack" and then just resolder yourself or take it to a repair shop.
Posted on Feb 21, 2009
  • 36 Answers
SOURCE: Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
Posted on May 23, 2009
SOURCE: Dell laptop charger
If the charger is older and since you saw the light go on then off again, it could just be the charger wires. Assuming your charger has a black box attached to it, try pushing the cord in towards the black box (usually the end leading to your laptop) . If that doesn't work, wiggle the cord in that area. If this works, your problem is simply the wire is worn out. You can fix it by exposing the inside wire where the bad connection is, snip it, reconnect and cover with electrical tape. I just did this to my sister's last week.
Posted on Oct 31, 2009
I cant plug my charger into my nextbook? why
It's not the right charger, or the connection inside it is broken. All this type of portable is susceptible to having the lead trodden on whilst they are lying on the floor. Look into the socket on the back and see if anything is blocking it?
Also make sure it is the charging socket and not the hole for securing it to a desk with a security device.
Jan 08, 2016 | Computers & Internet
Does not charge when switched on, laptop reboots when plugged in
Have you tried the laptop plugged in with the battery removed, you can get some odd behaviour with a faulty battery.? Is the charger the right one? check the voltage and amp's with what's on the laptop label. Have you tried checking the voltage on the charger ?or if you can try another charger. Is the plug a good fit into the laptop.? These are the easy/cheap problems that might cause these sort of problems after that it gets more complicated, I'm afraid. Best of luck.
Oct 26, 2015 | Audio Players & Recorders
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Characters walk around in circle and move backwards .Just bought Modern warfare 2.character won't walk forward only backwards and in circles.same problem in Grand theft Auto Games. My console is xbox 360...
It sounds like you have controller issues, try using another controller and see if they still walk circles. If the joystick is not in the centre home postion when you turn on console it will read left/right/etc as the centre. Also try using a different battery in the controller, mine has the same charging issue and i found that jiggleing the plug and play cord can sometimes turn the charger cord from green(or nothing) to red. Good luck..
Nov 16, 2009 | Microsoft Xbox 360 Console
Cant get it to turn on, it wont charge right. I put it on the charger, red light blinks and then stops. It will turn on, then right back off
Plug your phone in the charger and then take out the battery and put it back in. Or you can push the button to turn your phone on and then plug it in while it is starting up and it should catch on and start charging. It is definitely an annoying glitch, but a simple solution
Oct 12, 2009 | LG Incite Cell Phone
Compaq presario v2000 wont charge
It has happened to me as well since i have the exact same model laptop. The problem is a loose cable or the wire inside is damaged. I just bought a new charger since buying one is cheaper than taking the risks that the repair might cause a short after using it for some time.
Jul 26, 2008 | HP Compaq Presario V2000 Notebook
My laptop won't charge
the the power adapter is faulty luckily its seperate from the main board and is pretty cheap look on ebay or go to http://www.ifixit.com for parts and guides on how to repair it
Jun 28, 2008 | Apple iBook Mac Notebook
My sidekick 3 wont turn on
heres what i would say. let it charge for more than hr, and this bring it up to speed..if not i believe the battery may be defective, i just experienced this problem last night..the battery happen to be defective, then put another battery after awhile i went to sleep woke up, and it wouldn start...i let it charge for a while and it was good as new
Feb 11, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sansa e250 won't turn on
well , when you have something on a charger and the end that goes into the wall is unplugged and the other end is plugged in to whatever needs to be charged ... it drains the battery out and thats probley what happened to u. i have one 2 and you do not want to drop sansae250 ... i woner how you get videos and pictures on it .
Alyssa , 9 ♥♥♥♣♦
Feb 02, 2008 | SanDisk Sansa e250 MP3 Player
Lenovo G470 Core I5 4gb 500gb Hdd Laptop Blu-ray Logo
210 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
