Question about General Electric WBVH5200J Front Load Washer
How to reset control panel for wbvh5200j3ww - General Electric WBVH5200J Front Load Washer
    Top Expert:
  • General Master
  • 9,472 Answers
There is no reset. What is the problem you are having?
Posted on Nov 07, 2012
  • julie brooks
    julie brooks May 31, 2014
    i have a he front load and had to get a new control panel and forgot to set it to my washer before I started to wash and now I need to know how do I SRT it to my washer? please help!!!!!!
GE washer WBVH5200J3WW goes through part of cycle, then stops and the start/pause button flashes. I set it to the drain/spin cycle to finish. Have reset machine but it did not help. Any suggestions?
The biggest issue with these and all electronically controlled appliance is that they are susceptible to power surges and voltage spikes from your power grid. We are cautious enough to put our computers on a voltage spike suppressor, but not our computer controlled appliances. Since this particular issue is addressed when a trouble or fault code is displayed and you did not mention this, it could be any number of issues, but my money would go on a faulty motor control board. Now these are not inexpensive and without the trouble/fault code I would not recommend you buy one and replace it without an appliance repairman taking a look at it. Oh, and plug your appliances into a voltage spike suppressor they make them for both 120/240 systems.
Jul 25, 2017 | GE Washing Machines
Cold reset hp 3600n
To Perform a Cold Reset on HP Color LaserJet 3600n Printer
Step 1 - Turn the printer on.
Step 2 - Watch the control panel.
Step 3 - When the memory starts counting, press and hold the green (Select) button. Continue to hold Select button until all three Control Panel LED's are illuminated and on solid.
Step 4 - Release the (Select) button.
Step 5 - The control panel will display SELECT LANGUAGE.
Step 6 - Press (Down Arrow) button once. The control panel will display COLD RESET.
Step 7 - Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Jan 24, 2017 | HP Office Equipment & Supplies
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 10, 2015 | Refrigerators
I've got a ge front load model wbvh5200j3ww. Start wash cycle door locks drum turns one direction then the other then door unlocks. Nothing else happens
Sounds like you have a bad board and needs to be replaced.
Is this washer under warranty and if not did you take out an extended warranty?
Aug 27, 2014 | Washing Machines
We have a 2-year old GE washer WBVH5200J3WW brought from HomeDepot. It leaks water from the bottom. Any suggestions are appreciated.
Just started having the same issue (ours will be 2 yrs old next month) we are thinking its the rubber seal tube around the front that is worn out....
Jan 16, 2011 | General Electric WBVH5200J Front Load...
Can the door swing on a GE wbvh5200j3ww washer be switched?
AFTER PUSHING THE START/PAUSE BUTTON IT JUST BEEPS AND WILL NOT LOCK DOOR AND ELECTRIC SUPPLY IS GOOD
Nov 17, 2009 | General Electric WBVH5200J Front Load...
I had stored my ge frontloader washer and dryers for about 4 months and reinstalled them i turn the washer on and it runs threw its cycle and does not spin so the close are soaked in the washer the model...
I would remove the back and investigate for mouse/rat damage. If you had them in storage a rodent may have made himself a home. They like to chew thru wires and plastic components. Or a wire connection may have come loose when you moved them into storage or back from storage.
Sep 25, 2009 | GE WSXH208A Front Load Washer
Reset control panel for Whirlpool ADG 4952
whirlpool adg4952m is reading F2 and not working
Jul 04, 2009 | Dishwashers
Neon blue hurts my eyes
You might wanna reset your monitor's settings to default, just play with your monitor's options untill you find the reset to default option. If resetting the monitor's settings doesnt work, then try resetting your video card's settings. right click the desktop and open your video card's control panel, then look for the reset to default options, especially on the color settings, wherever they are (control panels for graphic cards vary by vendor ie ATI/Nvidia, and/or by the control panel's version)
Jun 11, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
General Electric WBVH5200J Front Load Washer Logo
209 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
