Cd player says no disc when loading a cd jvc xl-z555
    Master:
  • 689 Answers
The lazer is not reading the info off of the disc anymore, You could try cleannig it, But that usually damages the lazer eye,They are verry costly to replace, your better off just to look for a different one, You can get a good use one now a days for $10 to $40 at the most,
Posted on Nov 09, 2012
GazllFixIt
  • 103 Answers
SOURCE: JVC 5-Disc Player XL-F115
You won't get any sound unless you connect your CD player to an appropriate input on your amplifier (any but phono or tape/md) and connect your speakers to this amp.
Shout if you need more help.
Posted on Jan 08, 2008
SOURCE: cd changer won't open
try to open by hand,see if the tray is stuck.
opening by hand is you turn the motor.
if you put a power supply direct to the motor the pcb will be burnt
(giving a bigger problem).
Look for mechanical problems.
Posted on Mar 09, 2008
  • 37 Answers
SOURCE: i need parts for JVC XL-SV22 VIDEO CD PLAYER
look up it on ebay
Posted on Jul 14, 2009
  • 86 Answers
SOURCE: Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Posted on Oct 09, 2009
  • 382 Answers
SOURCE: jvc xl-f254 cd changer for home. 5 disc
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Posted on Jan 29, 2010
DISC WILL LOAD BUT NOT SKIP TO NEXT DISC
Possible failure of the loading mechanism of the set. You will need to remove and reset the loading section with a lot of care only if mechanically minded.
Sometimes a shift in the sensors can also reset the mechanism , so care must be taken to remove and reassemble.
Jan 10, 2011 | JVC XL-MC222BK CD Player
When I insert cd, in either 1, 2 or 3 slot and then it says no disc and opens...
Hello
Your JVC CD player has some mechanical trouble. It does not load CDs fully into the tray. Either tray loading motor or its belt iis faulty. Replace the belt first and see it helps you. If not replace the loading motro. For both, you have to open and disassemble your CD player. If you are able to do it, and have confidence, proceed. OK
Happy New Year.
Dec 31, 2010 | JVC XL-MV303 CD Player
DOOR OPENS WHEN DISK # IS PUSHED TO PLAY CD
This sounds like the disc is not completing the load sequence. This can occur if hte load belt slips and requires replacement. Try pressing play without a disc in place. If the the tray opens, then the problem is one within the command processing and will require additional diagnostics. At this point, you should get a detailed repair estimate. We should be able to guide you through the actual repair with that info.
Dan
Oct 29, 2010 | JVC XL-MV303BK 3-Disc CD Player
I have a JVC Karoke video XL-MV303BK and would like to hook it up to a Dell computer lcd monitor. What kind of hook up do I need?
If you have the eluse XL-MV303 manual, it probably tells you what the video can hook to.
If you don't have the manual try this XL-MV338 CD/Karaoke Player manual
http://www.retrevo.com/support/JVC-XL-MV338BK-CD-Players-manual/id/313ag921/t/2/
It appears to only have a composite video out.
Jul 20, 2010 | JVC XL-MV303BK 3-Disc CD Player
JVC XL-R5000BK CD Player
Not much to go on here. Are you using CDR-Music or Audio blank discs? That is all it will record on.
Feb 02, 2010 | JVC XL-R5000BK CD Player
Recording problem
try using + AND minus blank discs maybe it wont accept cd minus r CD - R Discs so try CD + - R DISCS
May 28, 2009 | JVC XL-R5010 4-Disc CD Recorder
JVC XL-SV22 Video CD
if cracks having in disc mean some times header does read disc! clean your header with disc cleaner!
Jul 01, 2008 | JVC XL-SV22 CD Player
Dec 30, 2007 | Audio Players & Recorders
81 people viewed this question
 Grubhead
Grubhead
