Question about Everstar Portable Heater/Fan
I need a manual for Everstar oscillating heater
I just need to know what the symbols mean on the heater
Everstar mpm 08cr bb4 manual
Try Googling (Everstar)(mpm 08cr bb4)(manual) without parens.
Oct 23, 2017 | Everstar Portable Air Conditioner Everstar
1) EHT not fired 2) CRT tube - No heater on 3) NO display
if no heater on crt tube the tendency was no display, that means the oscillation is not working and therefore fly back transformer will not work. now how are you going to locate the problem first you need to check the regulator if good then the horizontal out put transistor if it is not shorted. if one of this major part is defective circuit will not work. vertical section will just only wait to the horizontal output to oscillate. and every section will work after horizontal oscillate. good luck hope it will help you.
Jul 12, 2011 | Televison & Video
On the jandy 400 lt its displaying the AGS code... what does that mean?
Per your owner's manual:
AGS
(automatic gas shut-down)
1. Oscillating pump pressure.
1. Clean filter or identify and repair cause of pump oscillation.
2. Low gas supply pressure.
2. Identify and repair incorrect supply pipe size or pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners.
3. No flame at burners. 3. Identify and correct loose wiring connections, or problems with igniter, flame sensor, gas valve, or ignition control.
For more info the manual is here:
http://www.jandy-downloads.com/pdfs/LXandLT_H02140B.pdf
John
May 03, 2011 | Jandy Laars Lt 400,000 Btu Heater
My heater is blowing cold air.
Check a thing called a "Thermal Fuse" a little cylinder, or the like, in the Phase, somewhere, test to see if it is Open Circuit, It should be a Short, normally. If "Open" you need to replace it.
Feb 18, 2010 | Everstar Portable Heater/Fan
Everstar mpk 10 cr 1 manual, have an error code of P-1
It means that the little drawer for the water on the side is full of water or that it is not closed completly. In the water drawer there is a switch that makes it turn off the AC if it is running ,then it will give you a P1 code.
Make sure the water drawer is empty of water then. put the drawer back in carefully and gently, the switch that is built into the drawer will make contacts and your problem should go away. you might have to unplug the unit from the wall for it to clear the problem after doing the above steps.
Also here is a link to their site, Midea the company that makes these MPK-10CR units. For the owners manuel http://www.supportuscenter.com/documents/MPK_Manual.pdf
http://www.supportuscenter.com/pilot.asp
Sep 11, 2009 | Everstar Portable Heater/Fan
Don't know how much water to use
Do not put any water in the unit, the water that is in the unit drawer or bucket that is attached to the hose is a byproduct of the air conditioning process.
It transfers heat to cold and in the process produces condensation = Water.
May 30, 2009 | Everstar Portable Heater/Fan
Everstar Portable Heater/Fan Logo
60 people viewed this question
Top Everstar Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Everstar Pool and Spa Expert? Answer questions, earn points and help others
