Question about Refrigerators
Why did the temp. display go blank just leaving a blue led on my beco whirlpool freezer
Why did the Temp. Dislplay go blank, just leaving a blue led.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 07, 2012
peyton32034
  • 410 Answers
SOURCE: WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
funny you asked this question i just had this same problem this week at a customers home. you need the electronic control board located in the compressor compartment behind the refrig. it is mounted in the white box on the left hand rear corner. the whirlpool part number is 2304095 and it is around 175.00 i'm not sure who a local part supplier around you would be if all else fails you could get thru sears..
Posted on Jan 07, 2008
  • 27 Answers
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Posted on Feb 02, 2008
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
SOURCE: whirlpool frost free tropical, seems
Check the sensor in the refridgerator... on the right,,
Posted on Sep 22, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
Installed a new control board in a Whirlpool G15FSAXVY04, display reads PE0 000 flashing, what should I do next
You need to program the control board to match the refrigerator. Look for the serial plate and locate the number following "Code". That number is the program code and you will need that value.
1) press and hold Door Alarm keypad.
2) Press and hold the Freezer Temp Down keypad.
3) Release the Door Alarm keypad and wait 3 seconds. The refrigerator display should read PE - programming mode.
4) Press the Freezer Temp Down keypad to confirm that you are in the programming mode. Compare the Code number displayed to the one you recorded off the serial plate.
5) If they are the same, press and hold the Door Alarm keypad for 3 seconds to exit the programming mode.
6) Otherwise, press the Refrigerator Temp Up or Down keypads to change the first digit in the program code to get the correct value.
7) Press the Freezer Temp Up keypad to move to the next digit in the program code to adjust that. Use the Refrigerator Temp Up/Down buttons.
8) Repeat steps 6 and 7 until all of the digits match the Program Code from the serial plate of your appliance.
9) Press and hold the Freezer Temp Down button until the display begins to flash to save the code. If you hear a beep, the code is incorrect and was not saved.
If you heard a beep, return to steps 6 and 7 to correct the program code. Then go to step 9 again. If the code was saved, press any keypad to exit the programming mode.
I hope this helps.
Aug 08, 2015 | Whirlpool Washing Machines
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
Display screen temp. not matching temp. inside freezer .
most likely the temp sensing probe. Possibly the sensor has been moved from it original position and reading the wrong temp. too.
Jul 07, 2010 | Delfield 20 cu. ft. / 566 liter Upright...
Temp fluctuates in ge profile refrigerator and freezer
Mine is doing the same, but because we were getting frustrated with the interminted noise and motor we kept switching on and off until we realised the frig did not work at all. The key to our problem was, let the frig do its own thing as we realised it was auto defrosting. After 3 days of meddling with this thing, we thought we killed it. Just leaving it on and forgetting about it, it righted itself, and walla it has not missed a beat since. We even blew up another frig in the mean time because of the predicament we thought we were in with all the produce. Good luck and just let the frig do its own thing.
Sep 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
No digital readout
Hello derek143
You Said,
I have a Whirlpool upright freezer AFG 371/H there is a digital display and lights and buttons, on/off temp alarm etc running across the top of the freezer. None of this works but the freezer is still freezing. i have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
Sep 11, 2008 | Freezers
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool fridge freezer (american style)
you have a bad control or bad sensor
May 11, 2008 | Freezers
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
